Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2004 TL - How do I reset my "Check Engine" light?
Old Jun 26, 2007 | 03:44 PM
nikkums1021's Avatar
Default 2004 TL - How do I reset my "Check Engine" light?
What is the trick to easily reset the check engine light on a 2004 Acura TL?
Thanks!
Old Jun 26, 2007 | 07:53 PM
dtapia's Avatar
Default Re: 2004 TL - How do I reset my "Check Engine" light? (nikkums1021)
why not see whats wrong first and then clear it ?
Old Jun 27, 2007 | 07:59 AM
Good idea But do you know how to clear it? Thanks
Old Jun 27, 2007 | 08:06 AM
streetxdreamer's Avatar
fix the problem and it will clear
Old Jun 27, 2007 | 12:27 PM
Kenso's Avatar
HT White Ops
I believe most autozone stores will scan a CEL free of charge. I assume they would be able to reset it with their scan tool if you ask them.
Old Jun 27, 2007 | 10:32 PM
AL ASPIRATED's Avatar
Default Re: 2004 TL - How do I reset my "Check Engine" light? (Kenso)
how many miles do you have on the car? acura gives u a 4years 50k mile warranty
Old Jul 2, 2007 | 06:42 PM
ITR640's Avatar
I may be wrong but cant you scan through your info displaty by the guages using your info button and reset it?
if not go to the dealer
Old Jul 2, 2007 | 09:10 PM
Kenso's Avatar
HT White Ops
Default Re: (ITR640)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR640 &raquo;</TD></TR><TR><TD CLASS="quote">I may be wrong but cant you scan through your info displaty by the guages using your info button and reset it?
if not go to the dealer</TD></TR></TABLE>
You can reset the so-called "maintenance minder" system that way, but not the check engine light.
Old Mar 26, 2012 | 06:46 AM
Perry Hagen's Avatar
Your front or rear oxygen sensors are bad. Repalce and have mechanic reset the light!
Old Mar 26, 2012 | 06:47 AM
The autostores will no longer clear the code unless you keep it on the downlow!
Old Mar 26, 2012 | 09:02 AM
94eg!'s Avatar
#1 Super Guy
Loved
OMG! Why would you bump a 5 year old thread to post something so profoundly stupid? You have no idea what the guy's problem is without pulling the actual code. There are literally hundreds of different DTC's and any one of them will cause a CEL.
Some autoparts stores will let you use the scan tool and erase your own codes. Autozone by me wouldn't, but O'Reilly Auto does.
BTW: For future searchers, here is how you read the flashing D-light or Check Engine Light codes without an OBD2 or Honda scan-tool (OBD2 scanner can't pull D codes anyways). You still need a scan tool to delete CEL codes...
Originally Posted by 94eg!
Just grab a paper clip and read the codes yourself. Stick the paper clip in the DLC by the drivers right knee (as shown in this picture). Then switch the ignition to the "ON" position and watch all the lights start blinking. Long blinks are 10's & shorts are 1's. Just add them together to get the code for that light. If there is more than one code stored, they will be separated by a break between blinks:
This link has the definition for all check engine light blink-codes:
K20Tuned LLC*::*DC5/EP3 Codes
And here is a link to show the Transmission "D" light blink-codes:
http://www.piloteers.org/forums/14-p...tml#post387236
Write down all your codes and come back to THIS thread and let us know.
Old Mar 29, 2012 | 09:55 AM
joelmatt89's Avatar
also just an addition to this thread a lot of people think you need to go buy a fancy/expensive scan tool to read/clear code. You don't, just go onto ebay and buy a ten dollar obdII bluetooth tool compatible with torque which is an app. It will be able to show you ten times more than what an actual scanner would. This includes things like a graph of what voltage each of your o2 scanners is reading and tons more, basically if your ecu monitors it, it can tell you what the ecu is reading. I just have the free version of the app but for $5 you get a ton of options.
Old Mar 29, 2012 | 10:15 AM
94eg!'s Avatar
#1 Super Guy
Loved
Thanks. That sounds really great. I'm gonna have a look.
Old Mar 30, 2012 | 07:22 AM
SharksBreath's Avatar
thanks for the advice in this thread!
jb0705
Acura TL, RL & ZDX
Nov 5, 2006 05:15 PM
sherman
Honda S2000
13
Jun 22, 2006 04:13 PM
FF-Greg
Honda S2000
14
Mar 16, 2006 10:35 AM
IVI
Acura TL, RL & ZDX
Nov 23, 2004 07:29 AM
silvrintegra
Sep 21, 2004 11:25 AM
