AEM Plug-and-Play EMS with Wideband UEGO
Old Jun 26, 2007 | 03:19 PM
spuds's Avatar
Default AEM Plug-and-Play EMS with Wideband UEGO
http://aempower.com/ViewProduc...=1175
http://aempower.com/ViewCatego...ID=62
$1500 (Retails over $2100). Reply here for contact info.
New in box, top of the line, full instructions, tuning software and hardware, never installed, works as plug-and-play engine management system on any Gen2 Integra (same connectors as stock EMS). If you know how to cut and splice a wire it will work on any B series motor. Full software tuning wizard: plug it in, tell it your mods, make more torque and horsepower.
I sold my project before I got a chance to begin engine mods. Now I need a diff for the new project, so this has got to go. This system is perfect for anyone looking to get real performance benefit out of any non-stock B18 engine. Not many people run these computers since the cost when new is over $2100.
The other thing that really differentiates this system is the 20 channels of datalogging available. Download all significant data from a single pass at the strip, to a track session, or a run to Vegas. Hook up throttle position, wheel speeds, steering wheel position, shock pots, brake force sensors, or anything else.
This is from AEM's website (I highlighted the best features):
Installs in minutes using Plug & Play technology—no wiring necessary!
Start-up calibrations included
Live help window eases tuning process
Set-up Wizard creates a custom base map for your car
System is fully enabled—Never pay for upgrades!
Free software updates on aempower.com
Uses all the factory sensors
Runs on Windows™ compatible software
Fuel table automapping
Programmable traction control
Onboard 512kb datalogger
Up to 10 cylinder sequential fuel injection
16 general-purpose outputs
7 definable switch inputs
Electronic boost control
Soft cut rev limiters
Two step launch control
Wet or dry nitrous control
Definable knock control
Full idle control
4 EGT inputs with fuel control
16/32 hybrid high speed processor
Modified by spuds at 9:21 AM 6/27/2007
RealStreet
Feb 24, 2012 12:39 PM
GulfCoastRacer
Nov 2, 2009 12:16 PM
Innovation
Mar 16, 2005 06:22 PM
crxhybrid1320
Sep 17, 2003 05:29 PM
