is this a real exedy clutch.
Old Jun 26, 2007 | 03:13 PM
preludefien
Guest
Posts: n/a
Default is this a real exedy clutch.
http://cgi.ebay.com/ebaymotors...d=1,1
Old Jun 26, 2007 | 03:32 PM
jdmlude5
Guest
Posts: n/a
Default Re: is this a real exedy clutch. (preludefien)
it looks to be. but is a stock relacement clutch. but be carefull. i got my exedy stage 2 clucth and 8pd flywheel of ebay and 3 months later my throwout bearing is making noise
Old Jun 26, 2007 | 03:46 PM
AndyD's Avatar
Yes, that is a real Exedy clutch. ClutchCityOnline is a reputable seller. I have bought 2 clutches from them. I will only buy from them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">it looks to be. but is a stock relacement clutch. but be carefull. i got my exedy stage 2 clucth and 8pd flywheel of ebay and 3 months later my throwout bearing is making noise</TD></TR></TABLE>
That could be caused by improper installation.
Old Jun 26, 2007 | 03:47 PM
preludefien
Guest
Posts: n/a
Default Re: is this a real exedy clutch. (AndyD)
o ok so it will be no good with a turbo setup if its a stock replacement.
Old Jun 26, 2007 | 03:55 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">o ok so it will be no good with a turbo setup if its a stock replacement.</TD></TR></TABLE>
Depends on how much power you plan to put down. The stock clutch holds pretty well. It defintely holds better than what most people give it credit for. It's a great clutch for all-motor setups though. It would be better to go with a stronger clutch if you plan to turbo the car.
Old Jun 26, 2007 | 04:14 PM
s13_240sx_92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Yes, that is a real Exedy clutch. ClutchCityOnline is a reputable seller. I have bought 2 clutches from them. I will only buy from them.
Old Jun 26, 2007 | 04:15 PM
snobordboy's Avatar
Moderator
Default Re: is this a real exedy clutch. (s13_240sx_92)
+2
Old Jun 26, 2007 | 04:36 PM
preludefien
Guest
Posts: n/a
Default Re: is this a real exedy clutch. (snobordboi)
i plan to run about 320 at the wheel. will the stock be fine. its a advance autp clutch.
Old Jun 26, 2007 | 05:00 PM
kazx9r's Avatar
ebay = trash, don't buy anything internal like that on ebay they are usually manufacture defects, I bought one from aimcoclutch and when I was doing a rear sell replacement I noticed the disc had two cracks near the rivets on it after 10k miles
Old Jun 26, 2007 | 05:12 PM
cb7tougeracer's Avatar
Default Re: (kazx9r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kazx9r &raquo;</TD></TR><TR><TD CLASS="quote">ebay = trash, don't buy anything internal like that on ebay they are usually manufacture defects, I bought one from aimcoclutch and when I was doing a rear sell replacement I noticed the disc had two cracks near the rivets on it after 10k miles</TD></TR></TABLE>
not all ebay is trash got to know what to look for
Old Jun 27, 2007 | 11:17 AM
jdmlude5
Guest
Posts: n/a
That could be caused by improper installation.[/QUOTE]
i no how to change a clutch. it is really hard to mess up putting in a throwout bearing.
Old Jun 27, 2007 | 11:19 AM
jdmlude5
Guest
Posts: n/a
i would have to agree but not all is trash. but u r coorect about some defects. lucky for me i gotta change my trans anyway.
Old Jun 27, 2007 | 11:34 AM
BlacktraxGirl's Avatar
Default Re: (jdmlude5)
clucthcityonline is a great seller for clutches...they are actually one Ebayer that is great!
as for using that clutch for the power youre planning on putting down...i wouldnt. i would deffinately go for something more agressive and stronger. I personally would never use ACT but some people swear by them. I had that clutch in my lude and once i started making more power it just gave up...with only about 20k on it.
are you planning to track the car or drag the car or just daily it? those are all things to think about when buying a clutch because you dont use the same setup for all three.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">i plan to run about 320 at the wheel. will the stock be fine. its a advance autp clutch.</TD></TR></TABLE>
Old Jun 27, 2007 | 01:31 PM
preludefien
Guest
Posts: n/a
Default Re: (BlacktraxGirl)
it will be a daily driver.
Old Jun 28, 2007 | 04:00 PM
Default Re: (preludefien)
i woudl reccomend a 6 puck sprung hub with a copper one on the pressure plate side and organic or kevlar on the flywheel side
OrangeTeggy
Transmission & Drivetrain
Apr 2, 2009 07:43 PM
ericlee303
Sep 8, 2007 11:34 AM
akandok
18
Apr 17, 2007 09:43 AM
labatt50
Feb 24, 2006 06:11 AM
acuracy389
Sep 28, 2002 08:15 AM
