Ever burnt a valve?
Old Jun 26, 2007 | 01:37 PM
Wayne_Curr's Avatar
Default Ever burnt a valve?
I have...
And 2 shiny new replacements!
Edit: I do NOT have a Forced Induction engine...
Old Jun 26, 2007 | 01:43 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: Ever burnt a valve? (Wayne_Curr)
Nitrous? How did you do it?
Old Jun 26, 2007 | 01:47 PM
Wayne_Curr's Avatar
Default Re: Ever burnt a valve? (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Nitrous? How did you do it?</TD></TR></TABLE>
Going up a hill in 5th at WOT.
Completely stock engine lol.
This is why you dont do wide open rippers in 5th when you have FI.
Old Jun 26, 2007 | 02:50 PM
gsrious's Avatar
nicely done, on burning the valve.
Old Jun 26, 2007 | 03:31 PM
Liquidgsr's Avatar
Default Re: (gsrious)
how hard was it to change the valve?
Old Jun 26, 2007 | 05:12 PM
topcitylsteg's Avatar
DANG!!! thats one dead valve...
Old Jun 26, 2007 | 08:35 PM
Kyoto now's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne_Curr &raquo;</TD></TR><TR><TD CLASS="quote">
This is why you dont do wide open rippers in 5th when you have FI.</TD></TR></TABLE>
Wow, but I still don't get it. Does this happen all the time? I used to drive my Integra to work almost everyday up hill for about a mile at WOT and nothing happend. plus it had a b16 tranny. can someone explain how a valve gets burnt? thanks
Old Jun 26, 2007 | 08:38 PM
Emg's Avatar
Emg
Put it away!!!!
Old Jun 26, 2007 | 10:34 PM
REDLINETHIS23's Avatar
Default Re: (Emg)
sadd..seen someone bent a valve
Old Jun 26, 2007 | 10:36 PM
alexisthemovie's Avatar
Default Re: Ever burnt a valve? (Battle Version)
im also interested in knowing why wot going up a hill will burn a valve.
Old Jun 27, 2007 | 12:34 AM
sPaRk'iT's Avatar
Default Re: Ever burnt a valve? (alexisthemovie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie &raquo;</TD></TR><TR><TD CLASS="quote">im also interested in knowing why wot going up a hill will burn a valve. </TD></TR></TABLE>
x3
Old Jun 27, 2007 | 07:14 AM
Dartanian's Avatar
It is too much load for the engine. The EGT's go through the roof and stuff starts melting from the detonation.
Old Jun 27, 2007 | 07:28 AM
agrn93ls's Avatar
Default Re: Ever burnt a valve? (Dartanian)
I have had the same thing happen. wasnt cause i was going up hill though.
I was N/A at the time. so????
Old Jun 27, 2007 | 09:19 AM
Wayne_Curr's Avatar
Default Re: Ever burnt a valve? (agrn93ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">
It is too much load for the engine. The EGT's go through the roof and stuff starts melting from the detonation.</TD></TR></TABLE>
yep. although i think mine was either from an injector leaning out (less likely) or the machine shop thinks that a piece of carbon just got stuck in the valve seat and burnt through like a torch. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr &raquo;</TD></TR><TR><TD CLASS="quote">how hard was it to change the valve?</TD></TR></TABLE>
Easy "Hey machine shop, will you fix my head for me"
"yes sir, that'll be 234 dollars for 2 new valves and a resurface"
Damn thing came back like brand new
Old Jun 27, 2007 | 10:02 AM
Liquidgsr's Avatar
hmm i want to change my vavles, but i can't resurface the head myself. Im thinking of change my valves and springs.
Old Jun 27, 2007 | 11:13 AM
Wayne_Curr's Avatar
Default Re: Ever burnt a valve? (Liquidgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr &raquo;</TD></TR><TR><TD CLASS="quote">hmm i want to change my vavles, but i can't resurface the head myself. Im thinking of change my valves and springs.</TD></TR></TABLE>
I honestly think its worth the money to just have the damn machine shop take care of it.
Old Jun 27, 2007 | 10:48 PM
DAmnquickDA's Avatar
i did. detonated on nitrous. looked similar to yours except the damage was extended to most all the valves
Old Jun 27, 2007 | 11:14 PM
361 accord's Avatar
Default Re: Ever burnt a valve? (DAmnquickDA)
daaamn that was all the damage?
Old Jun 28, 2007 | 03:46 AM
Rzoops's Avatar
Other than replacing the valves, did you do all the other work? ie: Removing the head, etc
I am 99% sure I burnt a valve from the exact same reason at VIR for ITR Expo.
Old Jun 28, 2007 | 05:46 AM
Wayne_Curr's Avatar
Default Re: (Rzoops)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rzoops &raquo;</TD></TR><TR><TD CLASS="quote">Other than replacing the valves, did you do all the other work? ie: Removing the head, etc
I am 99% sure I burnt a valve from the exact same reason at VIR for ITR Expo. </TD></TR></TABLE>
Pulled the head, replaced some hoses, dropped head off at machine shop for milling and valve replacement (they automatically re-grind every valve and seat and replace all the stem seals while they're in there). Had 2 valves replaced. Cost me all in all (including head set gasket kit) like ~400 bucks cause I bought some tools along the way.
Old Jun 28, 2007 | 06:16 AM
Rzoops's Avatar
Are there any step-by-step guides you would recommend for taking off the head? I have the Haynes manual, and I've looked through a few team-integra articles.. but I'm curious as to what made it easiest for you.
Messing with the timing belt is my biggest fear right now, although there are plenty of guides for that step.
Edit: Right now I'm working with a full set of 16 brand new valves, 16 seals, a new head gasket, and some of those cotter pins. I have a machine shop lined up to do the work once everything is ready. Any other expenses I should expect?
tvrsir
Oct 19, 2021 09:14 PM
wrestler72
Sep 5, 2007 04:56 PM
95blackEG
Apr 25, 2006 10:28 PM
AreaSix
Feb 19, 2004 03:24 PM
obsidianG35
Jun 16, 2003 07:02 AM
