throttle cable on civic gsr swap
Old Jun 26, 2007 | 11:48 AM
eg6civic1538's Avatar
Default throttle cable on civic gsr swap
which throttle cable do i use stock civics or the gsr cable? and how do i run it??
if anyone has pics of this it would be cool....thanx in advance
Old Jun 26, 2007 | 12:19 PM
vsmhatched's Avatar
Default Re: throttle cable on civic gsr swap (eg6civic1538)
either a b-series cable will work or a custom mounting bracket for the d-series cable
Old Jun 27, 2007 | 08:35 AM
Gkdc182's Avatar
Get a throttle cable off a gsr so you can run it more cleanly over the intake manifold!!! It has a bracket so you can bolt it right onto the intake manifold..... looks better then running it behind and above the intake manifold!
Old Jun 30, 2007 | 02:50 PM
crxhybrid.'s Avatar
use the gsr and modify the brakced that holds it at the intake mani and it will work..
eggsi619
Jun 29, 2009 11:14 AM
DAmnquickDA
Jul 23, 2007 06:14 PM
1slow_ej8
Jun 7, 2007 10:04 PM
THEUSED
Dec 29, 2005 08:30 PM
gsrboy18
Oct 11, 2005 11:52 AM
