Valve question
Old Jun 26, 2007 | 09:05 AM
TurboEK9Coupe's Avatar
Default Valve question
I bought a LS/VTEC motor swap last year and I have had nothing but bad luck with the swap. Ok so here is my question. I had a timing belt failure about a month ago and it bent all of my exhaust valves. Not to bad. The swap came with a built head and a stock bottom end. I know it has Crower stage II cams and it has aftermarket valves, double springs and retainers. So I asked the guy that I bought the swap from what the brand name the parts that he used in the head and of course it was like talking to a brick wall. Do the aftermarket valves use the factory valve keepers or are they different. I want to ferra valves in the head but im not sure if my current components will work with those new valves? Thanks for the hep.
Old Jun 28, 2007 | 02:14 PM
Gkdc182's Avatar
the keepers should be the same...i am pretty sure
Skatnshawn
Jan 25, 2013 05:29 PM
clem kevin
Feb 26, 2009 01:09 AM
jdmjeff
Dec 21, 2005 02:18 PM
LsBack
Sep 19, 2004 01:04 PM
WykidEH
Dec 12, 2001 10:29 AM
