Retainers & springs for Type-S cams H22
Old Jun 26, 2007 | 02:28 AM
Lil Krayzee's Avatar
Default Retainers & springs for Type-S cams H22
Hi
i´got an Accord Type-R H22A7 the engine is the same which runs in the JDM Prelude Type-S.
I´m looking for better springs & retainers because i will set my rpm limit higher from 7800 to 8200 rpm, or is it not necessary?
thanks for every answer
Old Jun 26, 2007 | 05:17 AM
98vtec's Avatar
moderator emeritus
Default Re: Retainers & springs for Type-S cams H22 (Lil Krayzee)
i dont see any reason for upgrading to only up it 400 rpm. Hell, i take my stock h22a to 8000
Old Jun 26, 2007 | 06:50 AM
lude98SH's Avatar
Default Re: Retainers & springs for Type-S cams H22 (98vtec)
what cam are u using ?
Old Jun 26, 2007 | 07:14 AM
Default Re: Retainers & springs for Type-S cams H22 (lude98SH)
I will use the stock Accord Type-R cams, there are little bit more aggressive in the vtec than Type-S cams are. I`m not sure about if the stock springs & retainers can handle it?
@ lude98SH is it right that you have used a Mfactory final drive? What are your experince, i`m a little confused about the "cheap" price all the others are over 200$ expansiver.
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
Old Jun 26, 2007 | 07:36 AM
lude98SH's Avatar
no not yet should be going in in a few months. Finishing up the motor for now. Tuned by evans on 31st on july
wstef
Oct 12, 2004 04:29 PM
LudeyKrus
Oct 11, 2004 08:40 AM
CRXSleeper
Sep 9, 2002 10:47 PM
