Please I need to know the difference between an H23A1 and H23A3..
Hi thanks for looking. At the moment I have a blown H23A1 on a 92 prelude and I'm looking to swap an H23A3 JDM motor into it. My questions are though, what's the difference between the two? Secondly, will I have any issues with KL emissions? Are there any problems with the wirings? Finally, is the H23A3 OBD1 or OBD2?
Thank you for any info.
Ask user saikou, he just picked up an H23A3. I know it has a different valve cover from an A1, internal coil distributor, knock sensor, and auto tranny. Not sure what all else...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nemesis25 »</TD></TR><TR><TD CLASS="quote">Also, how do connect the knock sensor?</TD></TR></TABLE>
To what? You want to add a knock sensor to a block that doesn't have it or what?
Its a Euro Accord Motor.....
-H23A3-
2259cc
DOHC 16 Valves
87x95 Bore/Stroke
9.8:1 compression
158Hp@5800 RPMs
152Tq@4500 RPMs
Count on everything being the same as a USDM H23A1.....From what I can tell it was OBD2.
-H23A3-
2259cc
DOHC 16 Valves
87x95 Bore/Stroke
9.8:1 compression
158Hp@5800 RPMs
152Tq@4500 RPMs
According to my knowledge, the H23A3 was offered in both the Japanese & European markets. I asked Steve @ hmotorsonline, but have forgot what vehicle he said the motor came out of, in Japan. In Europe, this motor came out of the Accord wagon. There is a lot of false information floating around about this particular engine - hell, I could even be wrong - so I would give hmotorsonline a call and find out for sure.
However, upon retrieval of my H23A3, everything Hawkze posted is correct - different valve cover, internal coil distributor, NO knock sensor, and auto tranny. Everything else about the motor is exactly identical to that of the H23A1 motors that we are familiar with in the states. Mine is an OBD1 engine.
You will need to remove the knock sensor from your blown H23A1 and use it on the H23A3. Same with the external coil distributor from the blown motor, swap it over. Do not use the internal coil distributor from the H23A3.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saikou »</TD></TR><TR><TD CLASS="quote">According to my knowledge, the H23A3 was offered in both the Japanese & European markets. I asked Steve @ hmotorsonline, but have forgot what vehicle he said the motor came out of, in Japan. In Europe, this motor came out of the Accord wagon. There is a lot of false information floating around about this particular engine - hell, I could even be wrong - so I would give hmotorsonline a call and find out for sure.
You will need to remove the knock sensor from your blown H23A1 and use it on the H23A3. Same with the external coil distributor from the blown motor, swap it over. Do not use the internal coil distributor from the H23A3.</TD></TR></TABLE>
to everything.
to everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude »</TD></TR><TR><TD CLASS="quote">Hmotors sent me a H23a3 when i ordered one. everything is the exact same with mine....valve cover and all</TD></TR></TABLE>
Wierd...saikou's A3 had a different VC that says DOHC 16 valves. I'll post pics of it soon on my car because I stole it, ahahaha!
is there no port for the knock to screw in on the back of the block or, does it just not exist period?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">is there no port for the knock to screw in on the back of the block or, does it just not exist period?</TD></TR></TABLE>
There is a port for the knock sensor - same location.
there are a lot of anomalies with motors.....take this for instance
https://honda-tech.com/zerothread?id=1324196
my OLD motor with a H23a stamp, but w/o a vtec head.
my motor now has a H23a3 stamp sent to me from Hmotors...
My car came with a internal coil distributor on my f22a6. I have a H23A3 and need a internal coil dizzy do I use the H23A3 dizzy or can I use another one I want to stay internal coil even if I have to get a obd2 dizzy and get a conversion harness
