V-tec Problem...HELP!
Old Jun 25, 2007 | 08:26 PM
virgstyle's Avatar
Default V-tec Problem...HELP!
Whas up Guys... I'm a newbie...I have a b16 jspec, when driving in V-tec speedometer goes crazy...Any idea what the problem is and what i should do???
If any one knows, help me.
Thank you, i relly appreciate it.
Old Jun 25, 2007 | 08:36 PM
NiK's Avatar
NiK
Default Re: V-tec Problem...HELP! (virgstyle)
explaine crazy?
Old Jun 25, 2007 | 08:37 PM
virgstyle's Avatar
Default Re: V-tec Problem...HELP! (NiK)
Well if i'm at 40mph it just jumps to 60 mph and back when i'm in second gear entering vtec at 5200 rmp and the in third from 80 mph it just jumps to a 100mph and back and keeps on bouncing back and forth.
Old Jun 26, 2007 | 08:52 PM
slowcivic2k's Avatar
I believe that happened to Paul Walker too at 120-140 in the Fast and the Furious.
Perfectly normal... XD
Check your speed sensor wire harness, coolant finds its way down in there along with other crap, and the pins rust away.
Old Jun 26, 2007 | 08:55 PM
motor_man's Avatar
Default Re: V-tec Problem...HELP! (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">I believe that happened to Paul Walker too at 120-140 in the Fast and the Furious.
Check your speed sensor wire harness, coolant finds its way down in there along with other crap, and the pins rust away.</TD></TR></TABLE>lmao...
Old Jun 26, 2007 | 09:00 PM
hmtcrxsir's Avatar
its VTEC not V-tec, VTECH, V-TECH, VTEC get it right.
Old Jun 26, 2007 | 09:03 PM
HCivicSi23's Avatar
Default Re: V-tec Problem...HELP! (hmtcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">its VTEC not V-tec, VTECH, V-TECH, VTEC get it right. </TD></TR></TABLE>
Vtec actually... look at any OEM Honda Vtec sticker. Not VTEC lmao.
The 120-140 in the fast and the furious... god that part killed me. Got me hooked for the rest of the movie haha.
Check your Vss sensor, unbolt it and clean it. Then put it back in.
Old Jun 26, 2007 | 09:04 PM
hmtcrxsir's Avatar
Default Re: V-tec Problem...HELP! (HCivicSi23)
oh yeah? Where?
Old Jun 26, 2007 | 09:08 PM
HCivicSi23's Avatar
Sticker smarty.
Old Jun 26, 2007 | 09:10 PM
hmtcrxsir's Avatar
that aint no sticker.
Old Jun 26, 2007 | 09:11 PM
HCivicSi23's Avatar
My point exactly. ( Actually not every sticker, I correct myself )
Old Jun 26, 2007 | 09:51 PM
NiK's Avatar
NiK
only happens when your in vtec? or does this happen all the time?
Old Jun 26, 2007 | 10:08 PM
sageuvagony's Avatar
he said it's when entering VEETAK
Old Jun 26, 2007 | 10:54 PM
One92Eg6's Avatar
Default Re: (sageuvagony)
could be your speed sensor.... my car does the samething, just that mine will cut out and the speedometor wont read at all... Good luck...
"I live my life a quarter mile at a time!" hahahaa
Old Jun 26, 2007 | 11:45 PM
Default Re: (AllMotor909eg6)
Check your plugs, speed sensors almost never go bad, and the plug rusting issue is a VERY COMMON problem, happened to me and 3 of my friends so far, all failed because the blk/yel wire terminal rotted out.
Old Jun 29, 2007 | 09:59 AM
virgstyle's Avatar
Thanks for the help, i will plug the speed sensor out and clean it, but the check Engine light came on...So i think it's the speed sensor becuase now the speedometer does not work at all, so do i need a new speed sensor???
Old Jun 29, 2007 | 10:03 AM
BlackoutVTi's Avatar
"Well there's your problem, you nearly blew the welds on your intake!"
-some jackass in FATF
x2 check for rust on the plugs
Old Jun 29, 2007 | 10:23 AM
virgstyle's Avatar
I Plugged out the speedsensor, there are no rust, i will clean it and put it back in, will the check engine light come on again??
Old Jun 29, 2007 | 10:33 AM
instrument's Avatar
what're we psychics?
put the friggin thing back on and find out yourself
wtf?
Old Jun 29, 2007 | 10:43 AM
94c1v1cex's Avatar
Default Re: V-tec Problem...HELP! (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">"Well there's your problem, you nearly blew the welds on your intake!"
x2 check for rust on the plugs</TD></TR></TABLE>
maybe you should rip apart the block and replace the piston rings... lol this is great
Old Jul 11, 2007 | 07:06 AM
One92Eg6's Avatar
Default Re: V-tec Problem...HELP! (94c1v1cex)
umm i doubt the it will come on again... and if it does just reset it but unpluging your positive wire on battery. this should be your resort... make sure you are doin all of this while your car is off... good luck
Old Jul 11, 2007 | 07:11 AM
Syndacate's Avatar
Default Re: V-tec Problem...HELP! (AllMotor909eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virgstyle &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help, i will plug the speed sensor out and clean it, but the check Engine light came on...So i think it's the speed sensor becuase now the speedometer does not work at all, so do i need a new speed sensor???</TD></TR></TABLE>
Well the VSS code is 17 - I've seen it too many times in the last week to forget it.
So go here:
https://honda-tech.com/zerothread/1901557
And check your CEL - see what it is.
If it's JUST a code 17 and you tried plugging it back in and putting dielectric grease in there 'n such and still no go, it's most likely your VSS.
If it's NOT a code 17...tell us what code(s) it is.
Old Jul 11, 2007 | 07:45 AM
mister_ej1's Avatar
Default Re: V-tec Problem...HELP! (Syndacate)
ur car is just that fast dude....
ahhh the power of vtec haha
Old Jul 11, 2007 | 09:27 AM
2wheelhunter's Avatar
Default Re: V-tec Problem...HELP! (mister_ej1)
in mine the problem was the cluster itself.. just replaced it and never happened again
Old Jul 11, 2007 | 09:29 AM
akunamatta's Avatar
* B A N N E D *
Vtec, VTEC, V-tec, v-tec, or VTEC......****
