idle is low on b16a2
Old Jun 25, 2007 | 08:16 PM
stock99si's Avatar
Default idle is low on b16a2
yea my idle is really low its like 200-300 when warmed up, the car doesnt like shake bad, but i guess u could say it trembles a little, anyone can tell me what sregular idle for b16?
Old Jun 25, 2007 | 09:20 PM
stock99si's Avatar
Default Re: idle is low on b16a2 (stock99si)
bump
Old Jun 25, 2007 | 09:23 PM
team speed freeks's Avatar
it might be 1 of your sensors on the intake manifold, is your engine light on???
Old Jun 25, 2007 | 09:28 PM
stock99si's Avatar
Default Re: idle is low on b16a2 (team speed freeks)
it was, for second 02 sensor, but i reset by unplug battery and it went away
Old Jun 25, 2007 | 09:30 PM
yea but your light is gonna come up again, if you havent fix the problem, but im pretty sure is 1 of your sensors on the intake manifold,
Old Jun 25, 2007 | 09:31 PM
wat kind of engine do you have?? soch, doch??
Old Jun 25, 2007 | 09:35 PM
stock99si's Avatar
its been about a month since i did it, nothin yet.
its a 99 civic si so a b16a2 dohc
Old Jun 25, 2007 | 10:53 PM
yup its your sensors, you got to check them... i had the same problem with mine, is either the sensors or you goota make sure that your gas cable thing under the hood is tigh enough, and not loose
Old Jun 25, 2007 | 10:54 PM
93egSLEEPER's Avatar
try adjusting the idle on the TB first then see if it is a sensor... always go cheap to expensive on fixing parts.
Old Jul 8, 2007 | 01:11 PM
Special B's Avatar
Default Re: idle is low on b16a2 (93egSLEEPER)
bump
Murilo EJ1
Dec 27, 2017 10:40 PM
chocolatesk8er10
Dec 4, 2008 07:30 PM
mattsthru
May 27, 2007 06:19 AM
93turbotegSAV
Apr 2, 2007 05:46 PM
MeanGreenEG9
Apr 8, 2003 07:06 AM
