car have problem need help
car stuttering when i accelerate some times it does it before is warmed up no smoke come out the exhaust could it be a bent valve or what lmk know what you guys think thanks
I like to check certain systems together.
I.E. - check everything in the ignition system to make sure your spark is good:
-Check your distributor cap to see if the pickups are still good
-Check the plug wires
-Spark plugs
-Check the timing
-Blah, Blah, Blah
Then start checking all of the components that get fuel to the cylinders... So on and so forth.
Good luck.
-Spark plugs
-Check the timing
-Blah, Blah, Blah
Good luck.
