ripped timming belt teath
Old Jun 25, 2007 | 05:48 PM
SOHC_me's Avatar
Default ripped timming belt teath
Well not sure if you call this ripped, or torn or shredded off, but whatever. So i come outside to my car and try to start it, and it starts then falls on its face right away, i try again and it falls on its face. So then i try with giving it throttle and it stays on, but as soon as i let go, it dies. So a few buddies look at it and we cant seem to find out why it won't start, so i get it towed to my house, Luckily it was only 5 miles away, and my friend had his dads trailer handy. We pull the head off and find out that part of the timing belt is shredded. luckily i didn't bend any valves so i just got to put in a new belt in and re time it. BTW the timing was off by 180 degrees. My question is that what was the main reason for this, me not checking if the belt was tight enough, from driving to hard, I do drive it pretty hard almost everyday. It was also the original belt, and I have roughly 50 -60 k on the motor. Also are there any products out there that can help me keep the belt tighter, or do i just need to be checking it evrey so often. also what about those toda high power belts belts, worth it? I plan to turbo it later and have about 230 whp. any comments or suggestions are welcome.
The belt
thought id fix some dents while waiting for parts.
Old Jun 25, 2007 | 07:35 PM
lswantsvtec's Avatar
Default Re: ripped timming belt teath (SOHC_me)
idk about tightening so often i never do, but i agree new belt is in order! i would just check every 20 thousand or sto make sure that it doesnt happen again
Old Jun 25, 2007 | 08:14 PM
SoTexDC2's Avatar
Have you ever removed the timing belt, or messed with the cover?
If no, I am not sure what would cause this.
Setting the tension is very tedious, be sure to follow the HELMS exactly as it says when you put the new one on, or this could happen again.
If you don't have a HELMS, you can download it here: http://www.hondahookup.com/manuals/
(Just register and find your car)
Also, how did you check for a bent valve?
Old Jun 25, 2007 | 09:15 PM
SOHC_me's Avatar
Default Re: (SoTexDC2)
closed the valves and then turned the head upside down and poured engine oil in it, and waited a day to see if any leaked through, none did so. Also they never hit when i was driving, in only started to happen when i started it, and i looked it doesn't looked like they even hit.
Old Jun 26, 2007 | 04:44 AM
g0tgot's Avatar
thats good...at least you dont have any bent valves......right?? ........that thing looks pretty old...its been around the block mang.......when you replace it get the water pump replaced as well
Old Jun 26, 2007 | 08:52 AM
SOHC_me's Avatar
Default Re: (g0tgot)
yup, got a water pump too. Do i need a new belt tensioner though, or can i go with out it?
Old Jun 26, 2007 | 10:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Oil molecules are alot larger then air molecules. You need to put the head on the block with a new head gasket and check compression.
Old Jun 26, 2007 | 10:58 AM
VTEC_PRODUCTION's Avatar
Default Re: (PatrickGSR94)
change it and try it...i did this on my gsr and it was alright after replacing the belt...
doc500
Apr 13, 2012 05:52 PM
slide inside
Oct 22, 2009 09:25 AM
Project_ED8
14
Mar 10, 2004 09:20 AM
ActiveAero
Aug 10, 2003 02:57 PM
flat-blk-HB
Jan 5, 2003 04:56 PM
