Slwo turn over
Old Jun 25, 2007 | 03:55 PM
LukieLuc's Avatar
Default Slow turn over
What can be the cause of a slow turn over when starting the car, i've changed spark plugs, spark plug wires rotor and rotor caps. I have a jdm h222a with my h23 tranny and starter on there with about 140,00 miles
Old Jun 25, 2007 | 04:26 PM
milanored92h22's Avatar
Default Re: Slow turn over (LukieLuc)
unscrew the brass screw on the throttle body (for more rpm) at idle
Old Jun 25, 2007 | 04:27 PM
xxmastermindxx's Avatar
don't know what changing the idle will do to help slow turn over?
how about your starter? maybe it's going...
Old Jun 25, 2007 | 04:31 PM
LukieLuc's Avatar
Default Re: Slow turn over (milanored92h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milanored92h22 &raquo;</TD></TR><TR><TD CLASS="quote">unscrew the brass screw on the throttle body (for more rpm) at idle</TD></TR></TABLE>
that will help the car turn over faster?
Old Jun 25, 2007 | 07:11 PM
LukieLuc's Avatar
Old Jun 25, 2007 | 07:15 PM
SteveoBA8's Avatar
Check your battery/cables. Check the bat voltage when cranking.
Old Jun 25, 2007 | 07:28 PM
LukieLuc's Avatar
Default Re: Slow turn over (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Check your battery/cables. Check the bat voltage when cranking. </TD></TR></TABLE>
what should the voltage be when starting? if its to low i need a new battery? More info needed
Old Jun 26, 2007 | 05:30 AM
LukieLuc's Avatar
Old Jun 26, 2007 | 05:34 AM
mattsnooz's Avatar
your battery should sit around 12-14.5 VDC. Do you have a multimeter? use dc setting across battery with car running. If not around there at ilde than it could be battery or alternator. If its maintaining voltage around there then its in your starter probably (you replaced everything else that could be wrong)
you replaced your alternator already didn't you?
Old Jun 26, 2007 | 05:37 AM
well what voltage are you getting?
normally in my experience, and reading around on here, a normal, charged battery is putting out about 12.8-13.5V. thats almost always what my batteries put out. charge voltage, when the car is running, is usually about 13.8-14.1V.
if you have a big voltage drop, below 12V, when you are starting, i'd say get a new battery.
Old Jun 26, 2007 | 03:14 PM
LukieLuc's Avatar
Default Re: Slow turn over (xxmastermindxx)
Okay I put the multimeter on the battery before I started it was like 12.6..... & when started it went above 14v & stayed above at like 14.1 So if my battery is good what can I check next the starter? How do I test it?
slowB20ej8
Jan 3, 2008 09:42 PM
98jdmek
May 20, 2007 12:04 PM
GetawayInMoscow
Nov 21, 2006 07:57 AM
vc
Aug 22, 2006 02:19 PM
tC_Dragon
Jun 23, 2004 04:26 AM
