Headlights went out!
Old Jun 25, 2007 | 03:00 PM
Twistedframe's Avatar
Default Headlights went out!
A few times last month my headlights would intermittantly go out and come back on while driving. They came back on each time after a few minutes of acting strange. I went camping just last week and took the car down a gravel road that may have proven to be too rough for some of the sickly electronic components in it, and the headlights just would not even come on that night afterwards making us have to leave the car at a nearby gas station all night, until we could pick it up the next day and drive it home.
Has anyone ever had anything like this happen to their cords? I'm wondering if the relay has crapped out or something, seeing as how the brights don't even work now?
Old Jun 25, 2007 | 03:15 PM
TheMuffinMan's Avatar
He knows where you live!
fuses?
check the wiring?
check the wiring inside?
Old Jun 25, 2007 | 04:19 PM
hondadude's Avatar
Default Re: Headlights went out! (Twistedframe)
headlights are highly over rated anyway! ! LOL
Sounds like a poor connection inside the headlight switch, you could try thumping on the steering column to see if it causes or corrects the problem.
Caveman test Rules
It is possible to carefully take the switch apart and clean the contacts/ re-tension the springs.
Old Jun 25, 2007 | 04:43 PM
minnie's Avatar
Honda head lights or even other model head lights are normal and just a minor problem. They're right! Just check the wirings, insaide wirings and don't forget to check your battery. It is more important to know if the battery is ok. Goodluck!!!
Old Jun 25, 2007 | 04:48 PM
minnie's Avatar
Honda head lights or even other model head lights are normal and just a minor problem. They're right! Just check the wirings, fuses, inside wirings and don't forget to check your battery also. It is more important to know if the battery is ok. Goodluck!!!
Old Jun 25, 2007 | 05:32 PM
technine's Avatar
Default Re: Headlights went out! (minnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by minnie &raquo;</TD></TR><TR><TD CLASS="quote">Honda head lights or even other model head lights are normal and just a minor problem. They're right! Just check the wirings, fuses, inside wirings and don't forget to check your battery also. It is more important to know if the battery is ok. Goodluck!!!</TD></TR></TABLE>
Also, check the bulbs out themselves just to make sure.
fire21
Oct 15, 2007 02:24 PM
Chewy Built !
Oct 4, 2006 08:26 PM
aaronhume
15
Nov 30, 2004 09:41 AM
Kellindal
Oct 21, 2002 11:43 AM
