Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Spring+Shock Questions
Old Jun 25, 2007 | 02:03 PM
TailZ's Avatar
Default Spring+Shock Questions
Well it's been over a year since I've owned the car and I haven't done much to
it besides what you see in my sig. Well at this point I really want to lower my
car. Some of you probably saw my other thread on Tanabe DF210s. I decided
not to get those anymore. I'm really looking at Neuspeed Race springs right now.
My civic has a 4 finger gap all the way around. (yes it's pretty high)
My questions for the neuspeed race springs are will the rear sag? I've seen
a few pics on the suspension post and some look great with the springs and
some of em' sag. I know neuspeed advertises them as 2.25" up front and 2.0"
in the rear. That's the main reason I'm so hesitant in getting springs. I really
don't want the rear-end sag. I know most of you guys would say "get coilovers"
but I'm a broke college student. Maybe in the future though..
As for the shock questions. I plan on running the springs on tokico blues. I did
some searching and some people with the race springs say it's fine but most say
get konis. As far as my driving goes I don't drive crazy. Point a to point b. I mainly
just cruise. I'm always easy on the suspension. Would these shocks be good
for my driving style? Also I know these shocks have lifetime warranty. How
does the warranty work? If these shocks were to blow will they get rebuilt
or will they send me new ones? I've emailed Tokico but I'm still waiting on a
response. Doesn't really say much on their site regarding their warranty.
PS: Also I know I'll def. need a rear camber kit.
That's about it..haha sorry for the long post! Just want to make sure before
purchasing.
Old Jun 25, 2007 | 02:23 PM
prelude_93vtec's Avatar
Default Re: Spring+Shock Questions (TailZ)
if your guna drop the car so low, get coil overs. i dropped my car very low before and messed up my shocks so be careful
Old Jun 25, 2007 | 02:34 PM
TailZ's Avatar
Default Re: Spring+Shock Questions (prelude_93vtec)
As stated in 1st post coilovers is a maybe in the future.
Old Jun 25, 2007 | 03:20 PM
jivi's Avatar
Ok, if you're on tight budget get the neuspeed red. No need for you to buy a new shocks instead you can use your stock one. just my two cents.
EDIT: Btw if you go for neuspeed yellow(race) you must replace the stock shocks or else it will damage sooner.
Old Jun 25, 2007 | 07:02 PM
Curiouz_G's Avatar
im a broke college student but i got ground controls with konis. took me a year to save but its well worth it. as of now, im pretty slammed on the stock SI alloys. i say save your money and get yourself a nice shock/spring combo or coilovers
Old Jun 25, 2007 | 08:34 PM
toyomatt84's Avatar
Sanji
I would get Ground Control sleeves long before any lowering spring setup. They're pretty well known for their reliability and performance.
$300 Ground Control's:
http://motors.search.ebay.com/...Zmppf
$350+ Tokico's:
http://motors.search.ebay.com/...soo=1
Old Jun 25, 2007 | 08:53 PM
TailZ's Avatar
Default Re: (toyomatt84)
for the gc and tokicos don't you have to modify the tokicos to get the gc on properly?
Old Jun 25, 2007 | 09:00 PM
toyomatt84's Avatar
Sanji
Default Re: (TailZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TailZ &raquo;</TD></TR><TR><TD CLASS="quote">for the gc and tokicos don't you have to modify the tokicos to get the gc on properly?</TD></TR></TABLE>
No, not really. If you want a super-slammed suspension, you may want to. But, in doing a slammed suspension, you'll need to do a lot of other work on the car to make it work properly. The tie rod ends would need to be flipped, otherwise you're going to have steering issues. And, that's just the beginning.
Old Jun 25, 2007 | 11:58 PM
UNBRE4K4BLE's Avatar
sorry to threadjack, but is anyone aware of whether or not ground controls will work ok with kyb agx's?
Old Jun 26, 2007 | 12:57 AM
toyomatt84's Avatar
Sanji
Default Re: (UNBRE4K4BLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNBRE4K4BLE &raquo;</TD></TR><TR><TD CLASS="quote">sorry to threadjack, but is anyone aware of whether or not ground controls will work ok with kyb agx's?</TD></TR></TABLE>
I don't see why they wouldn't be able to.
Old Jun 26, 2007 | 05:43 AM
Curiouz_G's Avatar
im pretty low and i have no steering issues. the only issues ive had with being really low i
-speedbumps
-driveways
-a creaking sound from my rears from being too low
Old Jun 26, 2007 | 08:09 AM
portaman03's Avatar
Tokico HP (blue) will most likely blow if you drop the car lower than 2". I would suggest an adjustable shock if you must go that low. Tokico D-Spec, Koni Sport (yellow), KYB AGX, etc. Stay away from the Tokico HP and KYB GR-2, they aren't meant to handle more than 1.5-2" drop.
In my opinion, I would be more concerned about my shocks blowing out than my rear sagging. When it comes down to the wire, I would choose a quality shock before I put my money on a set of springs. Springs can always be found cheap/used and undamaged however, the chances of finding used shocks are slimmer (as they blow).
https://honda-tech.com/zerothread?id=2001159
https://honda-tech.com/zerothread?id=2009897
Old Jun 26, 2007 | 09:23 AM
anonnonator's Avatar
Default Re: (portaman03)
what would be the best set up for a 01 LX in which I only want a 1" drop? And would I have to get a camber kit? As it looks like my rear tires are a little bit tilted already.
Old Jun 26, 2007 | 09:52 AM
Vantage's Avatar
Default Re: (anonnonator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anonnonator &raquo;</TD></TR><TR><TD CLASS="quote">what would be the best set up for a 01 LX in which I only want a 1" drop? And would I have to get a camber kit? As it looks like my rear tires are a little bit tilted already.</TD></TR></TABLE>
U will not NEED a camber kit although they are reccommended. I have H&R sport springs ( 1.3" drop F/R) and they are still within the OEM specs for camber, Therefore i haven't yet bought a camber kit.
As for the shocks, i would go for Tokico BLues ( HP's)
Old Jun 26, 2007 | 02:19 PM
TailZ's Avatar
so what exactly causes the rear to sag? is it the shocks or a bad batch of springs?
I know extra weight in the trunk will cause sag. Which is why I'm removing any junk
in the trunk. I guess suspension project will be on hold.. Need to save up on some
ca$h. hopefully looking forward to ground controls and koni/dspec.
Old Jun 26, 2007 | 03:00 PM
portaman03's Avatar
Default Re: (TailZ)
Rear sag can happen for a few reasons.. weight (as you mentioned), spring quality, and spring design (Tein S-Tech are naturally lower in rear) are a few reasons.
I would put my money on shocks first.
Old Jun 26, 2007 | 03:09 PM
so is it a normal thing for the 01 civic sag in rear?
Old Jun 26, 2007 | 05:50 PM
TailZ's Avatar
I think a much cheaper route then gc w/ konis is purchasing Omni Coilovers. Any good? I could get that and a rear camber kit for 900 flat.
Old Jun 26, 2007 | 06:01 PM
toyomatt84's Avatar
Sanji
Default Re: (TailZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TailZ &raquo;</TD></TR><TR><TD CLASS="quote">I think a much cheaper route then gc w/ konis is purchasing Omni Coilovers. Any good? I could get that and a rear camber kit for 900 flat.</TD></TR></TABLE>
$900 is cheaper than $775 (Aforementioned GC+Tokico setup, with a camber kit)?
Old Jun 26, 2007 | 06:07 PM
TailZ's Avatar
which tokicos are you referring to? blues or dspecs?
got a little confused..
this is one possible setup gc $330 shipped ebay, koni shocks $649 shipped from hopup,
and megan rear camber kit $111 shipped from robearracing. Total $1090
Old Jun 26, 2007 | 07:49 PM
portaman03's Avatar
Default Re: (TailZ)
I got my Tokico D-Spec (adjustable) from eBay for $500 shipped (seller jdm-in-stock). Koni yellows can be found for $550 shipped on eBay. Skunk2 sleeves are $260 shipped, and Ground Control sleeves are $330 shipped. A new set of quality springs will run you around $150 shipped. Front and rear camber kits can be found for under $100 shipped, bringing you to a total of $700-900 (depending on what products you choose, if you buy new or used, and where you buy).
Old Jun 26, 2007 | 08:37 PM
TailZ's Avatar
jdm-in-stock only carries dspecs for 01' and 02'.
..I have a 03' ahhwww I'm so frustrated.
same goes for the konis being sold for 530 shipped.
Old Jun 26, 2007 | 08:43 PM
portaman03's Avatar
Default Re: (TailZ)
drill the bolts out 1mm. easy fix. ask 'youngcity'.
Old Jun 26, 2007 | 09:13 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by portaman03 &raquo;</TD></TR><TR><TD CLASS="quote">drill the bolts out 1mm. easy fix. ask 'youngcity'.</TD></TR></TABLE>
2mm, actually. 14mm -&gt; 16mm front hub bolts.
Old Jun 27, 2007 | 12:25 AM
TailZ's Avatar
how low of a drop can dspecs handle?
Also if I were to drill from 14mm to 16mm wouldn't I need new bolts?
Modified by TailZ at 2:12 AM 6/27/2007
