Problem with my GSR after valve job and skunk2 intake manifold.
Old Jun 25, 2007 | 01:51 PM
z_life's Avatar
Default Problem with my GSR after valve job and skunk2 intake manifold.
I just got done putting the car back together after a valve job. I installed new valves along with skunk2 valve springs and retainers. While I had the head out I decided to go ahead and install my skunk2 intake manifold also. I got the car started and it has a problem.
When I get on the throttle past like 30% at any time the car will choke up and stall. If I get on the throttle lightly it will rev up. It will sometimes rev up from idle up to 4000rpm. When the car reaches 4000rpm it will choke and the rpms will drop and stall. If I press down on the throttle more to keep up the revs, it will choke and stall out.
I checked out the spark plugs and the car is running rich. I checked the timing and its good. Check engine light is not on. Would the problem have anything to do with my installing the skunk2 manifold?
I'm not sure what else to check but any suggestions would be great. I need to figure out the problem to get the car back on the road asap. Thanks in advance.
Modified by z_life at 3:05 PM 6/25/2007
Old Jun 25, 2007 | 03:51 PM
nokturnal_munkeeboy's Avatar
Default Re: Problem with my GSR after valve job and skunk2 intake manifold. (z_life)
what ecu are you? you might have to change your ecu to a chipped p28 or p28 with hondata s200 unit
Old Jun 25, 2007 | 04:12 PM
z_life's Avatar
Default Re: Problem with my GSR after valve job and skunk2 intake manifold. (nokturnal_munkeeboy)
running stock ecu
Old Jun 25, 2007 | 04:30 PM
that what your problem is , the ecu is thinkin that stock intake manifold on there but it not. your butterflies open at 4400 rpm then again when 5800 when vtec comes on.
Old Jun 25, 2007 | 04:35 PM
sPaRk'iT's Avatar
Are you sure the vlaves are seated right?
Modified by sPaRk'iT at 3:25 AM 6/28/2007
Old Jun 25, 2007 | 05:25 PM
doood's Avatar
been there done that
Default Re: Problem with my GSR after valve job and skunk2 intake manifold. (sPaRk'iT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">that what your problem is , the ecu is thinkin that stock intake manifold on there but it not. your butterflies open at 4400 rpm then again when 5800 when vtec comes on.</TD></TR></TABLE>
close but no. butterflies only open at 5800 and vtec is at 4400.
Old Jun 25, 2007 | 05:39 PM
z_life's Avatar
Default Re: Problem with my GSR after valve job and skunk2 intake manifold. (doood)
so the problem is the ecu? I didn't know the ecu had to be changed when installing a intake manifold. Can anyone verify this?
Old Jun 25, 2007 | 05:42 PM
doood's Avatar
the stock ecu is designed to work with the stock dual stage manifold. you typically lose some midrange when installing single runner manifold and keeping the stock ecu.
but, it sounds like you have other issues as well.
Old Jun 27, 2007 | 06:10 PM
z_life's Avatar
forgot the mention that my car is a 2001 GSR. I'm trying to source a chipped p28 ecu with the same kind of mods I have on the car. I'm out of ideas of what to check. Might just throw back on the stock intake manifold and see what that does. any other ideas would be great. Thanks
Old Jun 27, 2007 | 07:12 PM
AW's Avatar
AW
Just putting on the skunk2 manifold with stock ecu should not cause the problems you describe, all you should see is a decline in power in the mid range but it should continue to rev to the stock redline. When I changed to the manifold on stock ecu the car still ran fine except for loss in mid range power.
Old Jun 27, 2007 | 07:47 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
you took it to a machine shop... right?
i hope you didn't swap out the valves yourself without getting a real valve job done.
Old Jun 27, 2007 | 08:19 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Problem with my GSR after valve job and skunk2 intake manifold. (AW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AW &raquo;</TD></TR><TR><TD CLASS="quote">Just putting on the skunk2 manifold with stock ecu should not cause the problems you describe, all you should see is a decline in power in the mid range but it should continue to rev to the stock redline. When I changed to the manifold on stock ecu the car still ran fine except for loss in mid range power.</TD></TR></TABLE>
yeah. I just put one on my 99 GSR.
The OP: Your problems seem to be that you're running too much fuel. Are all your vacuum lines connected properly? Fuel pressure regulator line? Do you have a stock regulator or aftermarket.
Are you sure its running rich? Make sure your TPS isnt plugged into your MAP and your MAP isnt plugged into your TPS. The plugs are the same. Make sure everything is plugged in and tight.
Old Jun 27, 2007 | 09:04 PM
StreetRacinThug's Avatar
Check you MAP and TPS sensors! That is definately what happened to me! Sounds it exactly like it. Second since you removed your intake manifold and your throttle body make sure you bleed your coolant system.
Old Jun 27, 2007 | 09:58 PM
z_life's Avatar
Default Re: (full Circling)
Yes the head was taken to a machine shop
Old Jun 27, 2007 | 10:00 PM
z_life's Avatar
Default Re: Problem with my GSR after valve job and skunk2 intake manifold. (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure its running rich? Make sure your TPS isnt plugged into your MAP and your MAP isnt plugged into your TPS. The plugs are the same. Make sure everything is plugged in and tight. </TD></TR></TABLE>
Yes I double check the vac lines and they seem right. The regulator is stock.
I'm sure its running rich because I pulled out the spark plugs are they are super black. I'm going to double check the plugs in the morning.
Old Jun 28, 2007 | 04:01 AM
z_life's Avatar
Thanks everyone! I had plugged the wiring for the MAP and TPS wrong. I switched it up and that cleared the problem. Thanks again for everyone's help.
Old Jun 28, 2007 | 10:14 AM
Glad you figured it out. I think it's a rite of passage around here to get those plugs mixed up. We've all done it before.
Old Jun 28, 2007 | 12:43 PM
crx378's Avatar
do you have pics of the skunk2 IM installed. im doing one as well and kinda stuck. not sure what i need and dont need. also i have a str tb so have more hoses that i have no idea where they go.
Old Jun 28, 2007 | 06:59 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z_life &raquo;</TD></TR><TR><TD CLASS="quote">Thanks everyone! I had plugged the wiring for the MAP and TPS wrong. I switched it up and that cleared the problem. Thanks again for everyone's help.</TD></TR></TABLE>
lol...i rule so much. I SAID IT FIRST, BITCHES!!
Old Jun 30, 2007 | 09:33 AM
touintegra's Avatar
check your vacuum hose, its the ecu....i have the same **** like you and still running on a stock ecu.....depending on what stage you got for your cams......if you need any help just email me at touintegra1@msn.com
0evilEMPIRE0
Mar 15, 2004 06:22 AM
85mm LsVTEC
Dec 14, 2003 01:25 PM
Ls-Rturbo
Jul 4, 2003 09:53 PM
asianautica
Jan 11, 2003 09:50 PM
JDMkings
Oct 15, 2002 04:32 AM
