F20B Wiring problems
Well a friend and I attacked the wiring problem yesterday and I have a few ?'s
Image thanks to Bense
The sensor on the middle of the intake manfiold is the idle control valve correct? It has two coolant lines, one that goes to the water neck and one to the backside of the TB. My question is that on my D series its a two wire sensor but this one is 3, what do I do about that?
Also my civic harness plugs into the big plug on the obd2 distributor. I only have the two plug left with the fat blue and the black and yellow wires. Those are for tach correct. I ordered a jumper harness but it isnt the right one. What can I do about those wires. From what I know I think I just attach the blue wire to the coil ground inside the distrubitor. What about the black and yellow wire? TIA
For the IACV there is no way to hook it up, I have tried every variation, and looked through numerous wiring diagrams.
As for the Dizzy, are you obd-1?
I am assuming if you are that you will need to look at a wiring diagram for the dizzy, from a obd-1 civic, to a obd-2b. I have one somewhere I will try to find it.
The balck and yellow wire I think is the crank sensor?? I am not sure. Let me check.
-Braxton
-Braxton
hey brax katman has an article on his site about converting a 3 wire IAC to a two but I dont see how that would benefit me...any light on this topic?
http://technet.ff-squad.com/
CivicVX94
10
Apr 22, 2006 11:09 AM
vtecn8ive
11
Nov 8, 2005 07:56 PM
