GSR vs LS Oil Pan
Old Jun 25, 2007 | 05:57 AM
Daniel-sanB1's Avatar
Default GSR vs LS Oil Pan
hey guys, I had a Turboed B18b and I just picked up a B18C1
I'm boosted so I have the oil pan tapped. after doing some research I found out that the LS pan will not fit on the GSR, but the GSR will fit on the LS.
I'm positive they will bolt on to one a other, but I'm scared the oil return system is a little different.
I'm just wondering what must be done to put my LS Oil pan on my GSR
thanks
Old Jun 25, 2007 | 06:13 AM
dirtygsr94's Avatar
Default Re: GSR vs LS Oil Pan (Daniel-sanB1)
im pretty sure it will starve your engine of oil the sump fits too close to the bottom of the pan = no sumping action. the fix would be to buy a gsr pan. why dont you just use the gsr pan you have it would take all of 30seconds to weld a bung in it.
Old Jun 25, 2007 | 06:57 AM
CleanLikeJdm's Avatar
Hype-R Stalker
You would have to remove the block girdle on your Gsr block, to be able to use the more shallow ls pan.
Along with using the other oilpickup.
Old Jun 25, 2007 | 07:16 AM
Default Re: GSR vs LS Oil Pan (CleanLikeJdm)
removed the girdle...
that's exactly the answer I wanted.
so I'll re tap my oil pan.
thanks again.
Old Jun 25, 2007 | 08:06 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
tap your gsr pan! done!
Old Jun 25, 2007 | 09:19 AM
Default Re: (full Circling)
thing is,
it's a lot easier to interchange parts then the retap my oil pan (since I don't weld)
Old Jun 25, 2007 | 10:16 AM
rebo0t's Avatar
dont do it.. i used gsr pan on a ls block and it worked but gave me a max of 30psi oil pressure.
Old Jun 25, 2007 | 01:27 PM
Hype-R Stalker
Default Re: (rebo0t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebo0t &raquo;</TD></TR><TR><TD CLASS="quote">dont do it.. i used gsr pan on a ls block and it worked but gave me a max of 30psi oil pressure. </TD></TR></TABLE>
Did you use the stock ls pick-up still? That would be your pressure problem.
Old Jun 25, 2007 | 01:47 PM
projectTeG's Avatar
edit""" NVM
Old Jun 25, 2007 | 03:18 PM
get another return fitting, cut out a hole out on the gsr pan, take it to a muffler shop, and have them weld it up.
why would you do anything else? don't half *** your oil system. you know just as well as i do that this way would work with minimal problems. no offense, but the way you want to do it is questionable. i'd just tap the stock pan for piece of mind.
Boosted_B_Series
Apr 16, 2007 05:17 AM
Turbotype
Feb 21, 2005 11:15 AM
nevin
Dec 23, 2004 05:57 PM
filetofit
May 2, 2002 05:15 PM
DIRep972
Sep 22, 2001 11:06 AM
