differences between f22b1 and f23a1 (in reference to g23 thread)
Old Jun 25, 2007 | 05:08 AM
Andryzzle's Avatar
Default differences between f22b1 and f23a1 (in reference to g23 thread)
i know there are topics in the FAQ about the g series but none apply to the f22b1 block. im just trying to figure out what differences there are between the blocks of the obd1 f22b1 and f23a1 so if some of the h22 parts im selling dont find another home i know what to do with them. all i really know about the f23 is that the stroke is a little longer than on my motor. if this is the only difference i should be able to follow the thread in the FAQ exactly. are there any other things i should look out for?
Old Jun 25, 2007 | 05:38 AM
BlkChryKord's Avatar
Bore
F22 block = 85mm/3.346
F23 block = 86mm/3.385
Rod Length
F22 = 5.572
F23 = 5.551
Rod Width
F22 = .935
F23 = .780
BE Bore
F22 = 2.008
F23 = 1.890
Piston Compression Height
F22A1 = 1.203
F22A4 = 1.203
F23A1 = 1.181
Stroke
F22 = 95mm/3.740
F23 = 97mm/3.818
Mains Diameter
F22 = 50mm
F23 = 55mm
Rod Journal Diameter
F22 = 1.888
F23 = 1.771
Where you could've searched - https://honda-tech.com/zerothread?id=1232811
Old Jun 25, 2007 | 06:20 AM
Andryzzle's Avatar
Default Re: (BlkChryKord)
thanks, but what about mounting points for pumps, pullies, and external things (i.e. alternator) im probably going to need to use different belts too right?
Old Jun 25, 2007 | 09:29 AM
Default Re: (Andryzzle)
They should all fit 98% perfect. Belts, shouldn't be far off either. I have read that with the non-vtec G23 (F23 block, H23 head) you need a GSR timing belt.
Old Jun 25, 2007 | 09:57 AM
Andryzzle's Avatar
i figured they wouldnt have changed it too much but i have no experience with the f23 so i wasnt sure. thanks
Old Jun 25, 2007 | 07:57 PM
Lubo_25's Avatar
truly a worthwhile thread to look at dont forget to do a h22/h23 soon...
please_hop_off
Jan 6, 2023 12:32 AM
TomCat39
Honda Civic (2001 - 2005)
Mar 19, 2017 04:25 PM
(760)doogie
Oct 31, 2008 03:07 PM
NirVTEC
May 22, 2007 11:15 AM
mgags7
Apr 17, 2006 05:42 AM
