Smoke coming out of exhaust when hitting V-TEC. Is this Normal?
I have never had seen smoke come out of MY exhaust while in vtec, but everyone else I know regardless of what their setup is has smoke. So, to me technically I think its normal. Is it a GOOD thing? I have no idea. Maybe someone else who's more educated could explain why this happens.
same thing happens to me im guessin its cuz when u hit vtec ur oil pressure rises a good amount and thats just residual burnt oil. but i could b wrong
white smoke usually means head-gasket.
or
I would stop stomping on her and super reving the **** out of it too, it could be rings if its a blueish color
*edited* so people will and stop e-freaking/e-thugging/e-bashing like a bunch of high school punk kidz.
And yes I am sorry for somewhat not providing solid information when I posted. Next time I'll take the time to properly clarify my thoughts.
Modified by mattsnooz at 5:33 AM 6/26/2007
or
Ahhh....the notorious VTEC Cloud! I can't speak for everyones, but mine is some extra fuel making it out the exhaust due to running a test pipe. People that run cats are kicking some carbon out of it.....Just a couple thoughts, not guaranteeing nothing else is wrong.
never seen a car with vtec not spit out some smoke when hitting it :/ maybe you should change your oil er something if its real bad though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz »</TD></TR><TR><TD CLASS="quote">white smoke usually means headgasket. I would stop stomping on her and super reving the **** out of it or your gonna wreck your rings even more!</TD></TR></TABLE>
Headgasket, rings, wtf, you're confused here man.
Bluish-white smoke is oil, black smoke is excess gas, sweet-smelling bright white smoke is antifreeze.
When your headgasket is bad you could be burning antifreeze, and getting gas in your coolant system.
When your rings are bad, you could be burning oil left by bad oil rings on the cylinder walls, and you can be getting gas into the oil.
When you have bad valve stem seals, you burn oil due to it dripping down on top of the piston.
When a car smokes a puff after starting or sitting at a stoplight, that is valve stem seals, the oil smoke builds up as you idle and burn it and then puffs out when you take off.
If your car smokes white at high rpm you most likely have a ring problem, as the oil squirters on an h22 coat the cylinder walls well, and bad oil rings leave too much there, that would be the white smoke.
If you have black smoke in vtak, welcome to stock honda ecus, they love tuning them rich.
Guest
Posts: n/a
i got a question. not to thread jack but when i hit vtec i see dark grey/black smoke. running rich i would gather. but when i am coming to a light in gear but not on the gas clutch not pushed in i see i light smoke coming out. but after sitting at the light when i start to pull off it smoke a puff but then it does not after that. alve seals?
^^^ sounds like you have it down.
OP: I know that my car smokes when I hit Vtec from being too rich, but I've never been able to see it while I was in the car. It seems like you may have more then your share of smoke.
Have you done the normal tune up stuff?
it could be the grease in your headers...dont talk. rings and headgasket...where do the 2 meet in the whole scheme of things? Roll your car off a 5000 foot cliff, with you in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NNV »</TD></TR><TR><TD CLASS="quote">
it could be the grease in your headers...dont talk. rings and headgasket...where do the 2 meet in the whole scheme of things? Roll your car off a 5000 foot cliff, with you in it.</TD></TR></TABLE>
holy **** dude. I mean I don't really like that guy much either but ****.
Assuming your smoke is blackish, your computer is dumping fuel when you hit VTEC, and yes its normal, and its not exactly fun to get entirely rid of, even with tuning, but hey, you wanna play you gotta pay!!! Just wax the back nicely so its easy to get the black off, including your tip, nobody likes a dirty blowhole!
I had hEllA( is that the term the hip kids use??) smoke coming out of my exaust while in VTEC. Turned out to be a bad pcv valve...
smoke while hitting vtec is normal as it gets.
especially if you have a cat delete or aftertermarket exhaust bigger than 2.25 in.
my friend has a 2.75 and i see a little bit more smoke than stock when in vtec.
but do a leak down test as well.
Thanks for all the comments guys. lol i visited a auto shop and found this smoke stopper liquid u put into ur engine. it reduced alot of smoke from the exhaust! It was a gamble that it might *** up my engine by putting this smoke stopper into my engine after i got it serviced but it works!
******** make the world go round. Many of us are ******** because 75% of the people on this forum are retards and it pisses us off when members are so confident in the information they post when it came straight from their ***.
u havent contributed much to this forum so i would keep your mouth shut in case you ever need help in the future.
don't let the HT world politics grab you by the *** and pull you in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz »</TD></TR><TR><TD CLASS="quote">mgags, i know your god or whatever the *** u think u are(u condescending *****)but he never specified what color of exhaust. secondly you even repeated my answers being possible the problems!! So how the *** am I confused? I SAID RINGS, and said HEAD-GASKET". I was in a hurry and missed "or". I didn't mean to mean that both where connected but that they where both possible depending on colour of gas. Either way i just wanted him to stop beating on his prelude FFS!
I only don't like you because your and A$$HOLE. you don't like me because I said some dumb things! whos the person who should pull his head out of his *** just a bit. I know your a genius but that doesn't mean you should get to be an ***! OH and same goes for you NNV. </TD></TR></TABLE>
Confusious say: Kid with little brain, should not talk **** to man with big brain, otherwise they get flamed.
OR
Confusious say: Kid with grease in headers, should stfu when it comes to Prelude technical info.
OR
This isn't a chat forum, quit trying to talk to me!
And its not "big brain" as you say, its big ego. If it was big brain he'd know not to be so narrow minded because thats how primates never evolved and still to this day remain monkeys!
Being smart involves things onther than memorizing lots of knowledge. You could be a genius but not have a shred of commen sence. I happen to be an electrical engineer and a contstruction maintenance technician, and yes I don't know shiet about cars but I'm trying to learn. No offence but all I'm learning from some of you is how to be A$$holes and stuck up ******.
CAN we stop with this chat though in a "TECH" forum please? keep your personal comments out of here and I'll do the same!
So that was your contribution? You guys don't seem to really try to help anybody from what I noticed anyway. All I usually see in this "tech" forum is personal bashing and constant and consistent flaming and now I've been brought down to the same level.
I'm honestly done making personal comments on here. You guys can continue to bash and turn this into a chat forum. I'll reply as I like and provide what I can in a non discriminatory manner as how it should be and as it was requested by moderators. Peace!
having a better command of the language would definitely assist you on your quest for HT acceptance;
just (1)pause & (2) think, and/ or (3)search before asking silly questions or posting silly comments, like the one they're still riding you for;
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein »</TD></TR><TR><TD CLASS="quote">having a better command of the language would definitely assist you on your quest for HT acceptance;
just (1)pause & (2) think, and/ or (3)search before asking silly questions or posting silly comments, like the one they're still riding you for;</TD></TR></TABLE>
Stole my thunder......usually I will defend peoples poor spelling. Not everyone here has English as a 1st language......I don't see that as the case here.
Youre always FREE to speak your mind here.......if your mind is wrong, people will surely let you know.
93b18civic
16
Oct 11, 2002 05:16 AM
