Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2000 odyssey CEL TCC Solenoid
Old Jun 25, 2007 | 12:26 AM
vdub08's Avatar
Default 2000 odyssey CEL TCC Solenoid
I scanned the CEL code and it gave me a TCC solenoid open. i dont remember the exact code, and i didnt write it down because i borrowed it from my friend at the shop, but he told me it was my traction control solenoid.
What can i do to fix it? anybody have this problem before?
Old Jun 25, 2007 | 03:08 AM
Ross 2.0's Avatar
In a Junkyard near you.
you are going to need to post the exact code
Old Jun 25, 2007 | 09:17 AM
vdub08's Avatar
i'll try to get the exact code today, but i looked it up and TCC actually stands for Torque Converter Clutch?
Old Jun 25, 2007 | 05:41 PM
slo blue's Avatar
Default Re: (tofu9000)
has the transmission been removed lately? check for a broken wire at the plug
Old Jul 2, 2007 | 04:11 AM
MatterMatt's Avatar
Default Re: 2000 odyssey CEL TCC Solenoid (tofu9000)
Thats the Transmission Clutch Control solenoid. If you have a P0740, which is a transmission clutch system failure code, you will most likely need a transmission. How does it drive? Is there any slipping, hard shifting, or late shifting?
Old Jul 2, 2007 | 10:23 AM
vdub08's Avatar
Default Re: 2000 odyssey CEL TCC Solenoid (MatterMatt)
yea the shifting is pretty crappy. it feels like it struggles in between gears
Old Jul 2, 2007 | 01:44 PM
MatterMatt's Avatar
I'm sorry, I meant Torque Converter Clutch Solenoid. Yeah, that sounds like a Torque Converter Clutch Solenoid problem. If its P0740 you'll need a trans. for sure (I've done several trannys for P0740 DTCs). If you find a P0700 thats just a generic transmission failure code that most aftermarket scan tools (snap on, mac, etc.) throws because it can't read the specific code. You may need to go to a dealer to get the actual code using an HDS(Honda Diagnostic System). Even the HDS will give a P0700 if you don't go into the trans. diagnostic tools.
Lawrence Nguyen
Sep 14, 2021 12:12 PM
allvtecyo
10
Aug 2, 2014 11:07 PM
erupt323
12
Mar 18, 2014 12:34 AM
dagunit
Nov 9, 2004 05:16 PM
smeister
Nov 3, 2002 11:06 AM
