Ideas why ABS LIGHT IS on After installed my jdm front?????
Old Jun 24, 2007 | 08:48 PM
831gsr's Avatar
Default Ideas why ABS LIGHT IS on After installed my jdm front?????
Any one have an idea why my abs light is on since i put my front end on?
I am thinking maybe the installing the headlights blew the relay( i check the fuses). Also is there any way of checking the relay other than just buying a new one.
Or my other idea was when the shop welded on my rad support, but i dont think there are any brake lines that high up on the chassis. Any infor would be great, thanks
Old Jun 24, 2007 | 09:29 PM
no2unenolife's Avatar
Default Re: Ideas why ABS LIGHT IS on After installed my jdm front????? (831gsr)
try checking your abs reservoir, maybe its low or empty.
Old Jun 25, 2007 | 05:06 AM
Dogginator's Avatar
Daisy... Daisy...
Pull the ABS codes like you would a CEL. (Jumper the connector in the passenger kick panel and read the ABS light for codes.) It will tell you why it is on. There is a kink in the forum FAQ with the code list.
Old Jun 25, 2007 | 06:51 AM
RenzoDaPlayboi's Avatar
Default Re: Ideas why ABS LIGHT IS on After installed my jdm front????? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Pull the ABS codes like you would a CEL. (Jumper the connector in the passenger kick panel and read the ABS light for codes.) It will tell you why it is on. There is a kink in the forum FAQ with the code list.</TD></TR></TABLE>
Old Jun 25, 2007 | 08:13 PM
831gsr's Avatar
right on guys, i ll try em both let u guys know what happened
jrmullins85
Sep 24, 2015 05:40 AM
GotVTEC07
Sep 23, 2007 05:05 AM
joenoreason
Apr 28, 2007 08:56 PM
typeR564
Feb 26, 2007 10:35 PM
SlammedCD7
Nov 9, 2004 03:56 AM
