h22 into a 96 ek what ecu?
i have a 96 ek hb and am going 2 put an h22a in it
all my friends are telling me it will be fast but idk?
i had an oo si and that was slow as ****
all i need is an ecu
any ideas of which one i should use?
plz no flaming
and i did search
plz no flaming
and i did search
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">wont i throw a **** load or codes?</TD></TR></TABLE>
Why would you?
Why would you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
Why would you?</TD></TR></TABLE>
h22's in civics don't throw codes, faulty sensors and lack of sensors or poor wiring throws codes.
No, you need an OBD-IIa to OBD-I conversion harness for the ECU if the motor's OBD-I, if it's OBD-II you can just plug it right in (this depends on the year).
It shouldn't throw any codes unless something is wrong.
btw the guy putting it in told me 2 use a ecu 4m a 96-98 ex manual bc my stock ecu has no vtech and im wondering the 96-98 ex is sohc and the h22 is dohc does that matter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">btw the guy putting it in told me 2 use a ecu 4m a 96-98 ex manual bc my stock ecu has no vtech and im wondering the 96-98 ex is sohc and the h22 is dohc does that matter
?</TD></TR></TABLE>
Take this any way you want, but I'm going to say it anyways:
Pay a shop to get every part you need and install it for you. Leave your keys and your wallet, and walk away.
?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Take this any way you want, but I'm going to say it anyways:
Pay a shop to get every part you need and install it for you. Leave your keys and your wallet, and walk away. </TD></TR></TABLE>
Beat me to it.
Beat me to it.
if you really want to get the full potential of your motor and have the right ecu on your car get a virgin p28 and get it dynotuned.
this is the deal i traded my oo si with a **** load of crap wrong with it .. salvage...bent lower control arms and .....
4 a stock 96 hb dx
and a h22a with 40k with everything all the shafts and shifter crap
and he said he would drop it in my car 4 free i just need an ecu will that 96-98 ex ecu work or not ?
4 a stock 96 hb dx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">this is the deal i traded my oo si with a **** load of crap wrong with it .. salvage...bent lower control arms and .....
4 a stock 96 hb dx
and he said he would drop it in my car 4 free i just need an ecu will that 96-98 ex ecu work or not ?</TD></TR></TABLE>
Goddamnit, no. Listen, and listen well:
YOU NEED THE CORRECT ECU FOR THE MOTOR YOU'RE PUTTING IN.
If you have an OBD1 H22, you need an OBD1 H22 ECU. If it's OBD2A, you need an OBD2A H22 ECU ... etc etc etc.
So get the right ecu for the motor.
4 a stock 96 hb dx
nope your car is gonna run like ****. trust me i had an eg with a h22 and no stock computer runs right exept the p13 wich is the stock h22 ecu. i was running a p08 with a type r chip. it was a really good chip, i sold the ecu to my boy and he's running it on his h22 and that **** is FAST.
But im telling you, the best way to go is with this:
1) obdII to obdI jumper
2) an obdI p28 virgin ecu
3) and finally, dynotune that matha
Dude, a civic HB 96-98 ecu will not friggin work with the H22 motor properly...
What is wrong with you?
You need an H22 ecu to run it right.. or at least a slap in the face to take the advice we are giving you. Are you on drugs? Read the previous posts from the other members..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">so ill need an h22 ecu now all thats left is to find out if its obd 1 or 2 and if its obd1 i need a harness correct
o and cokes amazing btw lol
</TD></TR></TABLE>...........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">i called my local shop and they said a h22 ecu will work but it will make my car "slow" they said i need a p28 or p30</TD></TR></TABLE>
That shop is retarted and you should never go there again.
Most h22 civics on stock motors run 13's and mid 12's with stock untuned ecus.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9carlos »</TD></TR><TR><TD CLASS="quote">if you really want to get the full potential of your motor and have the right ecu on your car get a virgin p28 and get it dynotuned. </TD></TR></TABLE>
(What the HELL are you going to tune on a stock motor?)
