How to adjust the a/c belt tension
Old Jun 24, 2007 | 08:09 PM
joeEK00EX's Avatar
Default How to adjust the a/c belt tension
Hey well I have a problem with my D16Y8 it makes a noise when I turn on the A/C in my 00 EK EX so I'm guessing is my ac belt how do I tighten it up can you guys help? TNX
Old Jun 24, 2007 | 08:49 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: How to adjust the a/c belt tension (joeEK00EX)
The noise you are hearing is not a growl, right? If it is, it may be a bad A/C Idler Pulley Bearing. Here is a TSB:
http://www.tegger.com/hondafaq...e.pdf
But, to answer your question on how to adjust the A/C belt tension:
(Use the image in the TSB as a guide, so you know which is the pulley center nut, and which is the adjusting bolt.)
1. Loosen the center nut on the pulley (Loosen, don't remove).
2. Turn the adjusting bolt to get proper tension.
3. Re-tighten the center nut on the pulley.
Old Jun 24, 2007 | 11:23 PM
joeEK00EX's Avatar
Default Re: How to adjust the a/c belt tension (tech8)
Hey thanks bro preciate noise is gone.
On1wheel
Dec 28, 2018 08:44 AM
zx92027xz
Aug 22, 2010 07:51 PM
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jun 6, 2010 08:39 PM
Riptide_NVN
Apr 7, 2009 08:41 AM
