Anyone want something drawn in Solidworks for free?
Old Jun 24, 2007 | 08:07 PM
TurboSI56's Avatar
Default Anyone want something drawn in Solidworks?
I'm working up my Solidworks skills and if anyone wants something drawn, and or would like to give advice on operating solidworks to its most potential that would be great
I can't guarantee i can make it perfectly, so these drawings that are sent back should be checked by a professional
Old Jun 25, 2007 | 12:45 PM
DaveF's Avatar
Default Re: Anyone want something drawn in Solidworks? (TurboSI56)
single part or assembly of mutiple pieces ?
Old Jun 25, 2007 | 01:41 PM
RC000E's Avatar
Default Re: Anyone want something drawn in Solidworks? (dturbocivic)
Someone should do a how-to on how to basically design a manifold for us noob's at solidworks. I haven't been able to dedicate much time to it, but I'll love to mess around with some designs if I had that basic process down.
Old Jun 25, 2007 | 02:32 PM
TurboSI56's Avatar
Default Re: Anyone want something drawn in Solidworks? (RC000E)
Yeah, I can do single parts and then attempt to do an assembly. I'm trying to figure out how to model this pipe i made but it's making me scratch my head :-p
Old Jun 25, 2007 | 03:26 PM
RC000E's Avatar
Yeah, I mean, I assume you get the flange in then design the pipes as 90's and straights, then make an assembly. Only deal is I heard of "flex"....someone mentioned, but no "flex" button in solidworks so....
Old Jun 25, 2007 | 03:43 PM
Niles's Avatar
In PRO/E the easiest way to do manifolds is draw the centerline of the runner from the flange to the collector and then extrude a pipe along the centerline. Then you can mess around with cuts. The real pain the *** is drawing part of the runner centerline, then having to make a new data plane to sketch in to draw the next part of the centerline when the angles of the two parts your drawing are not coplanar. I'm told solid works is easier, but I'm a pro-e guy.
Old Jun 25, 2007 | 04:06 PM
TurboSI56's Avatar
let's go with the basics, what's the easiest way to make a 90 Degree 2.5'' pipe with say a 1.5d radius, start off with a 2d or 3d sketch? draw a circle? then extrude it some how at a 90 degree angle? or am i way off
Old Jun 25, 2007 | 04:32 PM
corrupt0r's Avatar
in autocad i would use the revolve command to do that...i imagine theres a similar command in pro/e and solidworks
Old Jun 25, 2007 | 06:49 PM
.dave's Avatar
i HAS questions ?
Default Re: (corrupt0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by corrupt0r &raquo;</TD></TR><TR><TD CLASS="quote">in autocad i would use the revolve command to do that...i imagine theres a similar command in pro/e and solidworks</TD></TR></TABLE>
Exactly how to do it.
Draw the ID and OD and a line a certain distance from the center of the two circles for the bend radius. There should be a button in the Solidworks menu that has a toroid (donut) with an arrow inside it. Click that and it should as you for the feature you want to revolve and what line you want to revolve it around. After that it should ask you how many degrees you want to revolve it.
Old Jun 25, 2007 | 10:01 PM
Sifu's Avatar
How the hell do you make shape transitions in solidworks? Like say I wanted a pipe that was square at one end and circle at the other?
Old Jun 25, 2007 | 11:51 PM
TurboSI56's Avatar
Default Re: (.dave)
I've got that tool to work right one time, all the other times it always says i need to select an axis of revolution, but i cant duplicate the same thing i did before.
Old Jun 26, 2007 | 08:05 AM
RC000E's Avatar
Default Re: (TurboSI56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSI56 &raquo;</TD></TR><TR><TD CLASS="quote">I've got that tool to work right one time, all the other times it always says i need to select an axis of revolution, but i cant duplicate the same thing i did before. </TD></TR></TABLE>
That's exactly where i was at last night. I need to continue working with it though. I've done five full tutorials so far, but nothing really has gotten me to work with that tool yet.
I made two circles, matching the dimensions of sch10 pipe, but then I didn't know if I should define the 2.25" height, or if I should draw an arc from the center of the circles, or what the heck I should do. I then just tried the revolve tool and tried selecting the origin, but that clearly isn't a line.
Should I do a 3d sketch of some type of line on the axis simulating the centerline of the pipe? Should I arc it, or does the revolve tool change it to an arc? I'm pretty much lost after the circles....lol.
Old Jun 26, 2007 | 09:14 AM
drumking15's Avatar
hell you gusy are making it harder than it should be...most pie sizes etc are downloadable from macmastercar....dl, import, and start assembling....
im also a pro/e guy myself....and cadd is my true home
Old Jun 26, 2007 | 12:01 PM
wreckedrex's Avatar
Add a centerline/construction line to the sketch and 90% of the time it will pick up on it automatically... Hang on, I'll try and pop off a screen shot...
Dan
Old Jun 26, 2007 | 02:28 PM
wreckedrex's Avatar
Default Re: (wreckedrex)
Sketch is green. You need a feature to revolve around...
Dan
Old Jun 26, 2007 | 02:40 PM
wreckedrex's Avatar
Default Re: (Sifu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sifu &raquo;</TD></TR><TR><TD CLASS="quote">How the hell do you make shape transitions in solidworks? Like say I wanted a pipe that was square at one end and circle at the other?</TD></TR></TABLE>
A loft feature. Create your sketches and hit the loft button, it looks like a square transitioning to a circle...
Old Jun 26, 2007 | 03:24 PM
.RTErnie's Avatar
Im building a computer just for solidworks...my current computer wont hack it.
Any suggestions on processors/amount of ram/ etc?
Old Jun 26, 2007 | 08:31 PM
Rosko's Avatar
Default Re: (.R T E r n i e)
heres a header flange and tube I threw together. The tube is a single 3d sketch and a seperate sketch (the ID and OD of the tube) is drawn perpendicular to the centerline of the tube at either end and then "swept" along the 3d curve.
Old Jun 27, 2007 | 05:55 AM
TurboSI56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckedrex &raquo;</TD></TR><TR><TD CLASS="quote">
Dan</TD></TR></TABLE>
Thanks, from all of the tutorials i read it just said sketch a line vertically and draw a circle next to it, none said anything about it being a centerline. Now it works perfectly. What would you use to model a pipe with multiple bends say a 3'' pipe that bends 4'' downstream at a 70 degree angle then 6'' after that at a 27 degree any direction.
Old Jun 27, 2007 | 03:23 PM
Rosko's Avatar
Thanks, from all of the tutorials i read it just said sketch a line vertically and draw a circle next to it, none said anything about it being a centerline. Now it works perfectly. What would you use to model a pipe with multiple bends say a 3'' pipe that bends 4'' downstream at a 70 degree angle then 6'' after that at a 27 degree any direction. </TD></TR></TABLE>
that would be a 3d sketch.
FWIW when I say centerline I mean the physical centerline of the tube, not the "centerline" command in Solidworks. You ARE right that it needs to be a regular sketched line, I just refer to it as the centerline of the tube as I'm sure others do too.
Old Jun 27, 2007 | 03:24 PM
Rosko's Avatar
Default Re: (Rosko)
IIRC there was a tutorial in there of an oven rack looking thing. If you can find that tutorial it is EXACTLY what you are trying to accomplish.
Old Jun 27, 2007 | 03:37 PM
Turbogixxer's Avatar
Default Re: (Rosko)
Nice, I just got solid works
Old Jun 27, 2007 | 05:10 PM
Blown90hatcH's Avatar
Default Re: (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">IIRC there was a tutorial in there of an oven rack looking thing. If you can find that tutorial it is EXACTLY what you are trying to accomplish. </TD></TR></TABLE>
There is. SolidWorks is pretty user friendly so it is a good program to start out on. I have been using Pro/E and SolidWorks since 2000. If you can get your work to spring for it, they teach an essentials and advanced course, as well as many others, that is pretty beneficial for a guy just starting out.
Old Jun 28, 2007 | 05:33 AM
TurboSI56's Avatar
Default Re: (Turbogixxer)
yeah the oven rack tutorial always gives me a weird error towards the end that says error the path intersects its self? i've tried to get that tutorial right 20 times and i get the same error every time right after you draw the circle and try to do the command to make it round
Old Jun 28, 2007 | 06:41 PM
What version of SolidWorks do you have?
