What happened to my Stage 1 Exedy Clutch!?!?!
I just got my B20 integra running and i drove it to the store. I have an Exedy stage 1 clutch and ACT streetlite flywheel on my car. Well when i was coming back i put it in first at like 5 mph and floored it (I know there is a break in period) But i just wanted to rev to like 4 grand once ( i know, dumb choice)...
So my car jumped for about half a second then just revved freely!! As if i had put it in neutral but it was still in first! Now it wont go into first and all the other gears wont engage. It goes into gear but its like its in neutral...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_spoon »</TD></TR><TR><TD CLASS="quote">Suscribed pretty much the same problem here but with my 240sx.</TD></TR></TABLE>Well, im not completely worried cause i go to school for this and my teacher is an ASE certified tech AND transmission rebuilder... Ive torn down trannies before if that turns out to be the cause, so whatever it is ill let you know... has anyone any ideas?
I know my slave cylinder was leaking before this happened...
Has anyone had this or something like this happen to them??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 »</TD></TR><TR><TD CLASS="quote">Axles might have popped out. can you still find your gears?</TD></TR></TABLE>Yeah, after searching i came across that idea too... Yes, i can still find every gear except first gear... First gear wont go in...
When i put in other gears (2nd,3rd,4th,5th,Reverse) and lift off the clutch i can hear a faint scraping sound...
axles probably not in all the way. unless u have lsd, if one is not in all the way it'll just spin. by the sounds of it u prolly broke or rubbed the teeth off the axles and f'd ur 1st gear up... i say check axles first make sure their snapped in. i had this happen to my crx with the passenger side axle.
EDIT: I found my problem. The passenger side axle was popped out. I almost yelled when i saw it cuz i was so glad thats all it was...
Why would it do that to me? Did i forget a snap ring or something? Also, can i just weasel that thing back in the way it is? Or do i have to take everything off?
Modified by BoltonGSR at 11:02 AM 6/25/2007
you just didnt put it in all the way, how i do it is i push it in all i can then i take a nice size hammer and bang it once on the other end then you should here a POP* now tug at it and see if it will come off eazy.
if it does then ur snap ring is busted or nto doing what its supposed to, normally it wont. now finish up by placing the other end into the hub and ur good to go. check to see if your teeth are still there.
SHystrdyGSRtdy
Apr 27, 2005 05:33 PM
