Which Tranny?
I'm planning on buying a transmission for my LS/VTEC setup. I have a b18c1 head on a b18b* (95 integra LS) block. I'm setting the car up for turbo. My question is, is there really a big difference between a Type-R tranny and a GS-R tranny, I see B18c5 trannys are a hell of a lot more expensive then the b18c1 tranny, is the b18c5 tranny REALLY worth the extra few hundred more? or will a b18c1 tranny do just fine.. There both LSD right? this is my first motor swap/setup, i'm still learning, any help with my questions will be appreciated..thanks guys..
The gsr tranny is not LSD. the ITR tranny may be geared too short for your liking. The ITR has a helical LSD though... but at the same time its more expensive. the ITR tranny is geared identical to a b16 transmission if that gives you a comparison.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metalbikes666 »</TD></TR><TR><TD CLASS="quote">helical...? lol</TD></TR></TABLE>
its a type of lsd.
go to team-integra and do a seach for LSD in their article section, it will explain everything in full detail.
I have read that the oem lsd isnt all that great for boosted applications. People have said its night and day between a quaife and a oem.
Ill be getting a quaife for my setup within the next year.
Im just saying this that way you wont waste your money now on a tranny with an oem lsd, when i think you'll want to upgrdae again later.
its a type of lsd.
Yep I've read that the OEM lsd isnt all the strong. And the gears are a bit too short for any amount of highway driving anyway. It eats engines... I have a b16 tranny in my car and its identical in gearing to the Type R
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">
its a type of lsd.
Im just saying this that way you wont waste your money now on a tranny with an oem lsd, when i think you'll want to upgrdae again later.</TD></TR></TABLE>
well as u probly know it depends on what size turbo and setup u have if ur runin low turbo on like turbonetics kit its different u can run lsd on it but it depends on what your power goals u want so it depends. i dont know what your runnin so tell us whats up and mabe we can give u more nwsers.
(anwsers) srry lol
its a type of lsd.
(anwsers) srry lol
I have a GS-R head on an LS block. Integra Type-R cams, Type-R valves and springs, and a minor port and polish on the head. No work done to the block. I'm now considering putting a higher compression piston into the block and not going with turbo, and calling it a day. BUT, i still think i want the power that turbo would give me, no matter what i do. I'm very undecided. I know I'm gonna want an LSD tranny no matter which way i decide to go..
depending on how much power youre making off the turbo, i would say ls tranny all day long. you will be shifting constantly with a b16/itr tranny and your top end will hurt a little. a lot of people think ls trannies are crap. in most cases they are but in a turbo situation, if youre making over 300hp then i would stay with a ls and put an lsd in it. if not then stay with an lsd gsr tranny
