Battery Kill Switch
Which one would u recommend. I like the push off one but I've also seen regular ones. Please let me which one is easy to use. Thanks in advance
I want to install one soon so I can go racing.
the push off is great, just finished my install, the good thing is, the cables are not too long. if you run just the reg on off switch, you have to relocate the batt to the back, or run 2 4ga cables atleast.
i like the maz kill. mine is all setup.
I have the battery in the back. I was looking at push/pull switch. I dont know if I want to go with Flaming River one or Summit one. Does anyone have experience between those. I also would like to know the quality difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT »</TD></TR><TR><TD CLASS="quote">why put the battery in the back when u drive FWD car?</TD></TR></TABLE>
no space in the engine bay.
why not beind the firewall?
my car still has the stock batery in it as of now..
fixing to put the battery kill behing the firewall then fun a shute cable back out the car to kill the power
looking at buying 1 of those 6lbs batteries. & for u "JDM" guys it will be carbonfiber
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT »</TD></TR><TR><TD CLASS="quote">why not beind the firewall?
fixing to put the battery kill behind the firewall, then run a morse cable to the back of the car to kill the power
this is probably the most logical way to do it, being there is less cable, and less chance for voltage drop along the cable. it is also lighter to run a single morse cable to the rear of the car(which is used to flip the switch on or off from the rear of the vehicle), rather than 2 , 4 awg battery cables all the way to the back + the switch in the rear.
</TD></TR></TABLE>this is probably the most logical way to do it, being there is less cable, and less chance for voltage drop along the cable. it is also lighter to run a single morse cable to the rear of the car(which is used to flip the switch on or off from the rear of the vehicle), rather than 2 , 4 awg battery cables all the way to the back + the switch in the rear.
well you keep the battery in the stock spot, and run a large cable to the switch, and run another cable from the switch back to the battery(you dont have to run large cable, but it would be smarter to be able to carry the amps). then you use a morse cable (which activates the switch) to the rear of the vehicle. these morse cables are very user friendly with a variety of cable stops and cable ends that you can chose from.
stolen from Tunerzine.com (this is the James Innes battery kill setup)
instead of having the kill switch in the engine bay, you can put it inside the car, under the dash, hanging off the side of the A-pillar or A-pillar bars if you have a 10pt cage
I used a Jeg's brand one that failed after about a week. Changed to a Moroso and haven't had a problem since. Please use a circuit breaker at the battery in case the wire shorts out and causes a fire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">flaming river good stuff.</TD></TR></TABLE>
x2
Here is mine....
Very easy to install. It's so easy even a Paki can do it....
x2
Here is mine....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .R T E r n i e »</TD></TR><TR><TD CLASS="quote">Now...according to NHRA rules you cant have the plastic Flaming River one correct? It has to be all metal?</TD></TR></TABLE>
pg. number/paragraph number ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote"> for some reason, i keep seeing em.</TD></TR></TABLE>
where at, Pep boys ? LOL
Not true.
It has to be non flamable. The flaming river is not. It's not plastic. It's a composite material.
And to my best understanding it's the plastic key type switches that are not allowed.
Not true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 »</TD></TR><TR><TD CLASS="quote">
That setup is sick. I guess I'm gonna order falming river one today.
Paki can do it all night long
Which post does the alternator wire go on?
</TD></TR></TABLE>That setup is sick. I guess I'm gonna order falming river one today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">
Which post does the alternator wire go on?</TD></TR></TABLE>
It goes on the battery side.
Is it just me or does your window say something about loving ****?? Haha!
</TD></TR></TABLE>Is it just me or does your window say something about loving ****?? Haha!
It goes on the battery side.</TD></TR></TABLE>
If it goes on battery side how does it kill the alternator cause you are still getting power from the battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">
Is it just me or does your window say something about loving ****?? Haha!</TD></TR></TABLE>
Why yes it does....
Why yes it does....
If it goes on battery side how does it kill the alternator cause you are still getting power from the battery.</TD></TR></TABLE>
Thats power FROM the alt to the battery. It works like this.... With the motor running and the switch closed the alt charges the battery and the rest of the system. With the switch open it kills the alt output power and the battery at the same time. I have tested it and it does work.... I know my electronics.
