Please help me find axle needed, just did a auto to manual conversion
Old Jun 24, 2007 | 06:13 PM
90teg's Avatar
Default Please help me find axle needed, just did a auto to manual conversion
It's a 98' Prelude automatic. I just finished converting it to manual. I was almost ready go for a test drive and realized that the new Intermediate shaft has a female end on the driver side (big hole). And my driver side axle also has a female end. I went to advanced and all they had were the female end type axles. I am using a M2A2 transmission. What axle can I use?
Old Jun 24, 2007 | 08:33 PM
mgags7's Avatar
wtf? your driver side axle only has a female end?
a driver side axle should look exactly like a passenger side, two male ends.
Old Jun 24, 2007 | 08:43 PM
mafia's Avatar
Default Re: (mgags7)
If SH has a femail side? not sure
Old Jun 25, 2007 | 04:38 AM
90teg's Avatar
I am talking about the inner cv, not the outer that bolts to the hub.
Old Jun 25, 2007 | 06:05 AM
mgags7's Avatar
Yes, and I'm telling you that both the inner and outer cv joints have male ends on both sides.
I'm gonna go get a pic for you.
edit:
http://www.raxles.com/ContentM...y.jpg
its linked because its huge, they both should look like that.
Old Jun 25, 2007 | 12:02 PM
90teg's Avatar
I get what you are saying now, I misread it the first time. I know that is the axle I need, what car/year does it come from?
Old Jun 25, 2007 | 03:08 PM
mgags7's Avatar
It comes from your car, your year. Just not AT
AT axles aren't female anyways.
I think you bought SH axles or something....can you take a pic of that thing?
Old Jun 25, 2007 | 05:01 PM
Giant_Bean's Avatar
if you check here: http://www.napaonline.com/mast...tId=8
it looks like the drivers' side has a female spline on the inboard joint. Are you using the intermediate shaft from the auto? it looks like for the 4th gens at least the auto had a male spline on both sides of the shaft, doesn't specify there for the 5th gens.
Old Jun 25, 2007 | 05:05 PM
90teg's Avatar
Yup, I checked with napa, pep boys, and advanced auto parts. They all sell axles for a 98' prelude with abs with a female spline on the inner cv joint. I just bought a non abs axle and it came with a male inner cv joint. That makes no sense, I thought all 98' preludes were abs equip'd?
Old Jun 25, 2007 | 05:11 PM
Giant_Bean's Avatar
Default Re: (90teg)
where did you get it, non abs should be 4th gen base models only. ( by the way just edited my first post)
Old Jun 25, 2007 | 06:15 PM
mgags7's Avatar
**** dude you're right....wtf am I thinking
your driver side axle should be a female and the intermediate shaft should have the male end on it....my bad.
Old Jun 26, 2007 | 07:26 AM
90teg's Avatar
No I can't use the auto intermediate shaft because it does not fit with the manual m2a4 tranny. I had to get a 5spd intermediate shaft which has a female end on the driver side. I just got the axle today, advanced auto parts only has axles for non abs 98' preludes. I told them that their computer is wrong and to order that part anyway. It came in today and it was a abs axle with a male inner cv end.
Old Jun 27, 2007 | 06:10 AM
90teg's Avatar
Ok here is the issue. When I put the manual transmission in the intermediate shaft would not go into the transmission because the part of the shaft that bolts onto the block made the shaft go in at a angle. So I bought a what I thought was 5spd half shaft it has a female end on the driver side. The old shaft had a male end, and I cant find a driver side axle with a male end they only come with female ends. So what am I suppose to do?
Modified by 90teg at 2:30 PM 6/27/2007
mikesp0008
Mar 21, 2018 05:44 PM
rgarrett
Transmission & Drivetrain
Oct 5, 2017 04:57 AM
hardcore97
Dec 6, 2012 01:11 PM
jaerikd
Oct 8, 2009 05:07 PM
frankenstienEk
Dec 12, 2006 09:19 PM
