broken spark plug
That's usually the case. Make sure its the right size plug, your engine is timed correctly, the proper sized head gasket is on there (i.e. not high compression, etc.), and that the head has not been milled past the acceptable limits.
broken sparkplugs are really bad.. i have seen them in a couple different scenarios... the first is the side electrode being melted off, which was from a boosted car running way too lean. the sparkplug otherwise looked ok, but was pretty white.
the other, i have seen the spark plug totally chewed up, and that was a piston that was destroyed to the point that a large peice of it smashed the end of the sparkplug. when i took the head off to do a post mortem, there was a hole in the piston. there was a hole in the side of the block though also.
dropping a valve also can cause you to smash a sparkplug, but i havent seen that one yet.
either way, i would do a compression test to see, because in most scenarios where a sparkplug gets mangled, you are looking at catastrophic failure
Hanmin
17
Mar 19, 2009 09:35 PM
waynex206
Aug 31, 2004 11:02 PM
