Just finished painting my hood , Need some help on wet sanding, etc
Old Jun 24, 2007 | 05:37 PM
kelviiv's Avatar
Default Just finished painting my hood , Need some help on wet sanding, etc
Greetings!
I am new to this body paint.
I have just painted my hood, it turned out great, i used Rust-O-Leum? paint.
After it dried up, I had lines and you can see the little bumps from the brush.
I was wondering what kind of sand paper do i use(grit)? and if it is better to wet sand it.
Also, what do i do after i wet sand the hood.
Also I was thinking about painting the whole car, and I want to use a spray gun. I have heard around and seen the prices on a "decent/good" spray gun. Anyone know where you can rent one? I figure the spray gun would prevent a LOT less of the little lines and shapes created.
Any help would be appreciated
Old Jun 27, 2007 | 11:10 PM
johnxboi's Avatar
Default Re: Just finished painting my hood , Need some help on wet sanding, etc (kelviiv)
wet sand with either 1200 or 1500 for buffing
if you are just looking for a smooth finish you could use 600 or 1000
Old Jun 28, 2007 | 04:08 AM
dc2go's Avatar
i hope you used a roller and not a brush...
first coat? if so then that wouldnt matter. just scuff it. then do another layer.
air gun or electric? i got my electric running one at home depot. decent price..you can always paint your fence or outdoor chair table with it too, lol. good luck.
Old Jun 28, 2007 | 04:22 AM
b18LS's Avatar
Default Re: (dc2go)
Yeah a brush might not have been the way to go. Go with a 1000-1500, then if you dont have a buffer finish with a 2500. Go cross directionally with each successive paper. Then use a rubbing compound or meguiars medium cut cleaner. From there you can go to a fine cut cleaner or swirl remover/ ploish of choice, then after a week or two slap some wax on. A lot of guys will say wait longer to wax, but I get rammy. Good luck....Also, its a good investment buying one of those 30 dollar cheapo buffers. It'll really spped things up.
Old Jun 28, 2007 | 06:33 AM
fventura03's Avatar
look through the $50 paint job thread, it has everything you need to know about this.
also check my thread where i documented my entire process.
https://honda-tech.com/zerothread?id=1857355
blb2397
Paint and Body
27
Jun 4, 2012 11:23 AM
BB1LOViN
Paint and Body
12
Dec 25, 2007 04:19 PM
Tuesdaynightfever
Oct 13, 2006 04:00 PM
sniperslayer
Feb 13, 2005 09:16 PM
