horn and stop light issue
Old Jun 24, 2007 | 05:33 PM
Burgess0909's Avatar
Default horn and stop light issue
95 integra se - The horn nor the stop lights are working. The fuse is good under the hood and has current running though it. I have tested for power at the rear of the car with the brakes engaged and nothing there. My turn signals work , but they are operateing fast. Nothing in the achives, any thoughts?
Old Jun 24, 2007 | 05:40 PM
93Ls-tegra's Avatar
Default Re: horn and stop light issue (Burgess0909)
did u check to see if the bulbs in them were blown???
Old Jun 24, 2007 | 05:42 PM
Default Re: horn and stop light issue (93Ls-tegra)
yea, bulbs are good on both sides.
tech8's Avatar
Global Moderator
Loved
Community Favorite
Your brake light switch may be bad.
Old Jun 24, 2007 | 05:43 PM
I am not even getting any power to the clip that connect to the tail light when i press the brake.
Old Jun 24, 2007 | 05:47 PM
93Ls-tegra's Avatar
Might be loose wireing connected to the bulbs i had that problem in my teg when i first got it.They were cut for some reason my car also has a rebuilt title.....so mabe the incedent the person got in before i got the car did it but just check for the hell of it
Old Jun 24, 2007 | 05:50 PM
Default Re: (tech8)
where is the brake light switch located?
Old Jun 24, 2007 | 05:52 PM
93Ls-tegra's Avatar
Default Re: (Burgess0909)
also u may have a bad fuse make sure u check them and while your at it check them all to see if there not blown just for future reference incase somethen else acts up with the car
(edit)srry just noticed u said u check your fuses my integra has them on the drivers side but the clutch haha...
Old Jun 24, 2007 | 06:18 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
After looking at some wiring schematics, the hondas/acuras have a fuse that shares circuits between the horn and the brake lights. If your horn doesn't work its most likely the fuse. Check the fuse in the underdash fusebox.
I was thinking at first, it may be the brake light switch, as the circuit seems to run from the horn through to the brake lights. The brake light switch is at the top of the brake pedal assembly, underneath your dash, look straight up and you will see it.
Check the fuses.
Old Jun 24, 2007 | 06:24 PM
Default Re: (tech8)
The horn/tail light fuse under the hood is good. I have tested it and it shows that current is still running though it. It seems that something is interupting the current after it leaves the fuses box, but I do not have the manual for this model. Thanks for helping.
Old Jun 24, 2007 | 06:41 PM
93Ls-tegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burgess0909 &raquo;</TD></TR><TR><TD CLASS="quote">The horn/tail light fuse under the hood is good. I have tested it and it shows that current is still running though it. It seems that something is interupting the current after it leaves the fuses box, but I do not have the manual for this model. Thanks for helping.</TD></TR></TABLE>
yea np if anything u could also bring to an acura dealer they'll fix it right up
Old Jun 24, 2007 | 06:52 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
It looks like there is a horn relay, in the underdash fuse/relay box. Don't know if they would have anything to do with it.
My mistake, the horn/brake light fuse (20A) was located in the underhood fuse/relay box, not the underdash fuse/relay box.
Old Jun 25, 2007 | 06:36 AM
Default Re: (tech8)
when i hit the horn button i can hear a click coming from the fuse box.
Old Jun 27, 2007 | 08:26 AM
davidv433's Avatar
whatsup guys, just had that same problem on 07 accord, i work at a honda dealership, one fuse for horn and brakes, i had to replace the horns cus they were bad, caused the fuse to blow. tha clicking you had when you hit the horn might be the fuse blowing.
Old Jul 1, 2007 | 05:58 PM
Default Re: (davidv433)
The fuses for the horn does not blow, however I will check the horns. A brake light switch was to blame for the brake lights, thanks to all who helped.
mackoy20
Dec 17, 2006 06:01 AM
flatblk
Nov 23, 2006 05:14 AM
slammedef06
Jan 3, 2006 12:40 PM
5speed4life
Apr 25, 2005 12:23 PM
JdmLsPwr425
May 4, 2004 03:58 AM
