Dual Voice Coil sub question
I have a DVC sub, but i have a mono amp. My question is how to take advantage of this feature without buying a new amp? I have made an ms paint diagram below.
Would that be an efffective and Beneficial "loop" connecting the additional input on the box? Or should i just leave it alone without that loop?
Modified by youknowwhoibee at 2:40 PM 6/24/2007
Since we're not mind readers around here, you might start by telling us make & model of the sub and the amp.....
"Beneficial loop" WTF? We can't answer that question without knowing exactly what those terminals attach to inside the box.
Again. We're not mind readers...
sorry, it was just a general question on how to hook up a DVC sub with a mono amp. Here is my setup. I didnt buy these items wuth the links.... just for a reference to what i have
-Alpine ported box
-Alpine Type-R 12" Subwoofer SWR-1242D
http://www.crutchfield.com/S-M...r+sub
-Alpine MRD-M605 Amplifier
http://www.crutchfield.com/S-M...DM605
-Tsunami 1.2 Farad Capacitor
http://www.crutchfield.com/S-M...P912U
-Rockford Fosgate 8ga complete wiring package
-Alpine ported box
You will not need to remove the sub, Alpine wires each VC to one set of the terminal, treat each set of terminals as a VC and wire them in parallel, it looks like there is a set of paralleling jumpers on the terminals already, so yes, you can wire it that way, [pix] as long as there is no connection between the two terminals with no drawing of wire going to them. or you can just connect to the upper or lower set
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">You will not need to remove the sub, Alpine wires each VC to one set of the terminal,</TD></TR></TABLE>
Didn't realize that was a preloaded Alpine box.
cool, thats how i have it as of now. I am at work so i planned on working on it when i get home. I have the bottom set of connections connected. It sounds good, but i didnt know if I was only using 1 voice coil. I wanted to take advantage of both.
94
