Assembly help
Old Jun 24, 2007 | 12:01 PM
stock99si's Avatar
Default Assembly help
hey, im planning on installing skunk2 full coilover kit for my em1, im just wondering about how long will this take me, what kind of tools i need, and is there a high chance of ruining something trying to install it myself?
Old Jun 24, 2007 | 12:21 PM
doood's Avatar
been there done that
Default Re: Assembly help (stock99si)
it's pretty straight forward. just dont get hit in the face by a flying spring. that'll ruin your day.
Old Jun 24, 2007 | 12:33 PM
stock99si's Avatar
Default Re: Assembly help (doood)
well i got new shocks and coilover with springs, so i wont have to mess with taking off the spring off the old shocks. about how many bolts are there per shock, not including taking off the wheel
Old Jun 24, 2007 | 12:40 PM
doood's Avatar
unless your coilovers came preassembled you'll need to reuse a few parts off the old shock/spring combo
Old Jun 24, 2007 | 01:32 PM
stock99si's Avatar
im getin everything new, bushings all the things neccesary for the spring and shock.
Old Jun 24, 2007 | 01:43 PM
stock99si's Avatar
so how long will it take me to do it in a driveway?
Old Jun 24, 2007 | 01:58 PM
smileycvc's Avatar
it depends on how good you are with cars. If all you have to do is remove the old suspension and bolt the new stuff right in, I could finish it in an hour. If its your first time though I would give it 2 to 2.5 hours.
Old Jun 25, 2007 | 05:44 AM
stock99si's Avatar
Default Re: Assembly help (smileycvc)
yea i just gotta removie old shock n spring and put new shock n spring in.
is there a lot of room for mistakes or what?
Old Jun 25, 2007 | 09:58 AM
smileycvc's Avatar
no just put the front on the front and the back on the back.
Old Jun 25, 2007 | 12:21 PM
stock99si's Avatar
alright souds good.
lets say i get them preassembled ready for my installation, what toold would i need (not counting the wheel tools)
Old Jun 25, 2007 | 12:26 PM
smileycvc's Avatar
17mm socket, 14mm socket, the stuff to remove the wheels. Thats all I can remeber that might be it. If you have to undo the lower ball joint then you will need some pliers cotter pin and a hammer. Usually you can get it in with out that though.
Old Jun 25, 2007 | 07:20 PM
stock99si's Avatar
okay, ive been asking around and everyone says the bolts might have bee siezed up in the back.
well the pervious owner lowered my car before he sold it to the dealership. and before i bought it, the dealership removed the springs at put stock springs back on, does that mean that their not siezed anymore. FYI: i bought the car like 3 months ago.
Old Jun 26, 2007 | 05:45 AM
stock99si's Avatar
Old Jun 26, 2007 | 05:50 AM
97Ej6mike's Avatar
Some WD40 or PB-blaster would solve that problem. Just be careful not to snap any of the rusted/siezed bolts.
Old Jun 26, 2007 | 06:13 AM
stock99si's Avatar
Default Re: (97Ej6mike)
and just one last question, does anything have to be torqued? or should i just tighten everything as much as i can?
Old Jun 26, 2007 | 06:21 AM
mikeycivic's Avatar
Default Re: (stock99si)
who needs torque
Old Jun 26, 2007 | 06:22 AM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">and just one last question, does anything have to be torqued? or should i just tighten everything as much as i can?
As much as you can without breaking anything will be fine.
Old Jun 26, 2007 | 06:26 AM
averyvm's Avatar
Yo just jump right in and turn some wrenches. When it comes to those suspension bolts I just tighten them to feel. (just give those bolts a good turn)
Old Jun 26, 2007 | 08:20 AM
meangreenEG's Avatar
Check this DIY out:
https://honda-tech.com/zerothread?id=2012076
It's for 2001-2005 Civics but u can apply the same idea.
After you're done make sure u get an alignment and set the toe to zero. Depending on how low the car is going to be, u might need a camber kit.
Im probably gonna use that DIY myself, to put in my tokico illuminas and skunk2 coilovers....
Old Jun 26, 2007 | 08:48 AM
stock99si's Avatar
Default Re: Assembly help (meangreenEG)
iight well i really appreciate that post, let me know how it goes when u do it.
Old Jul 5, 2007 | 09:10 AM
my shocks come in this fri hopefully... hopefully it can be the weekend job...ill keep u updated
Old Jul 5, 2007 | 09:17 AM
stock99si's Avatar
yea mine are coming in friday as well, i got skunk 2 full coilover pro series.
Old Jul 5, 2007 | 09:29 AM
sweet.... where u live?
i also found another DIY here: http://www.honda-acura.net/for...41236
Old Jul 5, 2007 | 09:32 AM
stock99si's Avatar
i live in IL u?
Old Jul 5, 2007 | 09:38 AM
jmm96gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">it's pretty straight forward. just dont get hit in the face by a flying spring. that'll ruin your day.</TD></TR></TABLE> LOL, that would ruin your day. stock99si, it's a pretty straight forward install. Just take your time and be safe (support the car properly).
