i need some torque specs....
Old Jun 24, 2007 | 06:57 AM
95teilhatch's Avatar
Default i need some torque specs....
for my b18a1. i had to change my head. does anyone know the torque for the head studs and the cam straps? or do you know of an internet site that lists those torques? thanks.
Old Jun 24, 2007 | 07:28 PM
Default Re: i need some torque specs.... (95teilhatch)
bunp....its pretty hard to beleive that no one knows these torque specs. i need these and only these to put my motor back together. someone please help.
Old Jun 24, 2007 | 07:34 PM
mgags7's Avatar
how about you get a manual before you pull your engine apart next time
Old Jun 24, 2007 | 07:35 PM
Combustion Contraption's Avatar
Im going to assume you mean the cylinder head BOLTS, since that is whats used stock.
Anyway, use a 2 step sequence on the head bolts. First, TQ them all to 22 lb/ft, then TQ them all to 61 lb/ft.
The cam straps/caps should be tightened to 7 lb/ft.
All this info is direct from Honda.
Old Jun 24, 2007 | 07:54 PM
Default Re: (mgags7)
how bout you stop being an ******* and try to give some advice that is usefull.
Old Jun 24, 2007 | 07:55 PM
Default Re: (Combustion Contraption)
i have arp head studs....is it the same tq? im assuming they are. thanks for the help combustion. im not sure why there are ******** who just look for reasons to burn ppl on here. if they would stop spending time looking for posts that they can rip on, then they might have more time to work on their POS themselves.
Modified by 95teilhatch at 12:05 AM 6/25/2007
Old Jun 24, 2007 | 08:47 PM
onepoint6i's Avatar
Default Re: (95teilhatch)
make sure you use that moly lube on the nut base and threads..torque to 65ftlbs
Old Jun 24, 2007 | 10:25 PM
ToeJam's Avatar
http://www.hondahookup.com/
download
Old Jun 25, 2007 | 10:00 AM
No, ARP studs and OEM bolts are different TQ values. When using the lube that comes with ARP's studs, they call for 75 lb/ft, but a few people i know bump that figure to 80.
Old Jun 25, 2007 | 01:20 PM
thanks man....you helped me out alot.
midnitesol
Apr 22, 2007 12:08 PM
greddy13
Dec 28, 2006 11:40 PM
xXx Justin xXx
Apr 1, 2004 07:20 PM
