brakes
Old Jun 24, 2007 | 05:39 AM
snapper1978's Avatar
Default brakes
ok i got a 95 teg ls and just replaced the rear calipers and everything a few months ago now when i drive the brakes work fine and when i come to a complete stop it is like i have to keep pressing harder on the brakes like almost until the brake is to the floor.this happens almost everytime i brake,if you just keep the same pressure on the brake the car will slowly start to creep forward.any ideas what i need to look at?
Old Jun 24, 2007 | 06:19 AM
Exeed's Avatar
Default Re: brakes (snapper1978)
Did you check your brake fluid? If it's not completely full, check for leaks on your BMC (Brake Master Cylinder) and if it leaks, replace it.
Old Jun 24, 2007 | 07:41 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Probably the brake master cylinder needs to be replaced. With age, it is common for the seals to go bad, many times you may not even see a leak.
Old Jun 26, 2007 | 12:41 AM
bluE R's Avatar
if there isn't any visible leak around the master cylinder, try bleeding your break system first..
Old Jun 26, 2007 | 01:23 AM
polodinks_gsr's Avatar
mines does the same on my 94 gsr....somtimes when its real hot outside and air is on i can feel it going down but no leaks maybe needs to be bled?
Stanceman
Dec 28, 2017 05:41 AM
90 integraian
Suspension & Brakes
Sep 25, 2008 05:11 AM
crxtreme27
May 19, 2003 12:04 AM
GSR95T
Sep 4, 2002 09:21 AM
integra0260
Jul 12, 2001 12:51 PM
