No Catback, how loud? and how much power?
Old Jun 24, 2007 | 04:56 AM
Doodlydo's Avatar
Default No Catback, how loud? and how much power?
I'm planning on removing my Cat-back and putting in a bigger resonator. So I was wondering if anything had this done and how loud the exhaust is after Cat-back removal?
After talking to a couple of my friends they said I could be looking at 30hp gain roughly, so I wanted to know if anyone has gotten a dyno after removing there Cat-Back.
I plan on using 2.25 in pipes btw.
Thanks.
Old Jun 24, 2007 | 06:05 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: No Catback, how loud? and how much power? (Doodlydo)
Wow.. gtfo is you're trying to be serious.
if you just Seriously believe your friends, go punch each of them in the face.
But, I doubt it since, you say you're "removing" the catback,
then you say you plan on using 2.25 piping, so you're putting a "bigger" catback on.
Either way .. you're not making 30hp off anything on one single mod like i/h/e.
Old Jun 24, 2007 | 06:18 AM
nWilk666's Avatar
Default Re: No Catback, how loud? and how much power? (CleanLikeJdm)
loud as expletive. not much gains unless its a open DOWNPIPE for turbo, still not much gains just faster spool by not much.
Exeed's Avatar
If you remove your catback COMPLETELY, as in, nothing else after the header. You can expect to gain, 3-7 HP, depending on what exhaust system you had previously.
I.e. If you had an Apexi WS and you take it off, the difference wouldn't be all that grand. But if you had a stock LS piping (1.93 inch bleh) the difference might be more towards 5-7 HP gain. This is just being a little overcompensatative. To find out for real, you're just going to have to actually dyno with and without the catback.
Old Jun 24, 2007 | 08:51 AM
TurdBlown Teg's Avatar
your going to make no low end power at all!
Old Jun 24, 2007 | 09:01 AM
b20acura's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doodlydo &raquo;</TD></TR><TR><TD CLASS="quote">I'm planning on removing my Cat-back and putting in a bigger resonator. So I was wondering if anything had this done and how loud the exhaust is after Cat-back removal?
Thanks.</TD></TR></TABLE>
wow 30hp gain... you've got some pretty optimistic friends.
Old Jun 24, 2007 | 09:18 AM
Exeed's Avatar
Default Re: No Catback, how loud? and how much power? (b20acura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura &raquo;</TD></TR><TR><TD CLASS="quote">
wow 30hp gain... you've got some pretty optimistic friends.</TD></TR></TABLE>Optimistic doesn't quite cover it.
Old Jun 24, 2007 | 09:52 AM
1.8L_allmotormilitia's Avatar
30hp GAIN? lmao
Old Jun 24, 2007 | 10:06 AM
l2Y4N's Avatar
Default Re: (1.8L_allmotormilitia)
don't forget to remove the most power robbing piece of the exhaust system, the header! yup, my friends said you can get another 30hp without it.
Old Jun 24, 2007 | 11:05 AM
Remyessy's Avatar
ll COGNAC ll
are you talking about taking out the CAT CONVERTER???, because that's what it seems like... then you want to use 2.25 in pipes.
if you remove your cat converter you'll be loud, and if you run an open header, your even louder. I'm not even going to comment about that 30whp gain.
"you...you..you crazy man, you crazy but I like you"
Old Jun 24, 2007 | 11:09 AM
alexisthemovie's Avatar
i do this once in awhile when im bored with how my car sounds. it sounds awesome basically, almost like a ferrari 360 with capristo level 3.
you lose a lot of bottom end! i cant stress this enough. the top pulls really hard so what it does is basically move your power band even higher up than it already is. very impractical if you plan on driving it far. its also extremely smelly and smokes a lot.
pburke23
May 10, 2004 03:16 PM
sd_pinoy858
May 10, 2003 10:15 AM
SuperRice
18
May 30, 2002 10:26 PM
mr9o
Nov 17, 2001 12:58 AM
96tegsr
Oct 18, 2001 06:46 PM
