wobbley ride?
My 97 civic dx coupe wobbles in the highway, when i go past 70. The wheels are balanced but when i jacked up the right front side of the car, I grabbed my tire and I can wobble it from side to side (Left to Right not Up or Down). Does anyone know what it can be? Oh yeah my suspension struts are blown and i need alignment. I hope that helps. Alright help me out A.S.A.P! thanks!
wow, thanks for the quick feedback. But I dont think its the tie rods because, when I wobbled it I noticed the part where my camber kit connects to this other piece. And that peice moves as i wobble my tires. And my friend said that, the bushing that is connected to the camber kit and this other piece is suppose to have play, but the other left side of my tire doesnt wobble, when i try to check if its suppose to have play, the other left side is stiffer than the right side. Should i just replace the whole tie rods?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importfan0103 »</TD></TR><TR><TD CLASS="quote">any noise when you turn?</TD></TR></TABLE>
No noise when I turn. Its defently not the axels because, my friends and I checked that already.
well, i could move my wheel from side to side, while having my hands placed in the sides of the wheel. It feels like the lugs are loose but they're not. SO i replaced my wheel bearing and it solved that porblem
yes sir, the only time it gets crazy and woobles is when im on the highway. When i drive the legit speed limit which is 65mph it doesnt wobble, but once i go over that and hit 70mph and beyond, it wobbles dangeriously. Like the whole steering wheel shakes and my car starts to rock and it feels like the left front tire is taking control. And town fair tire said my tires are balanced out evenly too..
dude, i can alomst assure you that its the wheel bearing...mine was just like that and only got worse when faster speeds where going on. Dont keep driving around on it like that, get it fixed as soon as you can...the more you drive, the worse it gets
oh yeah, i forgot to mention. When i drive in the highway on the straight aways, thats when the wobbling starts to begin when I hit beyond 6mph. But when I make one of those wide turns on the highway when the highway starts the curve, i hit 70mph and the wobbling stops. It only wobbles insanely when im driving straight on the highway going 70mph. I hope that was good information? alright thanks agian!
i've never done it, cause when it was going out...i replaced my whole brake assembly, hub and everything...cause i had some stock dx brakes in the front and crappy drums in the rear. So i just upgraded to Si front and rear. But wheel bearings have to be pressed in im pretty sure
fixed my wobbley situation! i bought new outer tie rods for 25bucks at autozone! and slapped it right on today, and my car runs with great handling and the shaking stoped! THANKS GUYS
hybrid90
Suspension & Brakes
14
Feb 27, 2008 03:35 PM
Dwight Schrute
Suspension & Brakes
Aug 15, 2006 11:03 AM
