B16a in CRX motor is boging out PLEASE HELP!!!!!!!
Old Jun 23, 2007 | 09:28 PM
Drizzle_kid's Avatar
Default B16a in CRX motor is boging out PLEASE HELP!!!!!!!
I just bought a 91 CRX with a B16a under the hood, but when i start it, the motor runs rough and when i give it gas it bogs down and back fires sometimes, does anyone have any ideas on what could cause this and how i could fix it, please let me know.
Thanx alot,
Kyle
Old Jun 23, 2007 | 09:31 PM
cb07's Avatar
Fuel pump? Just throwing it out there.
Old Jun 23, 2007 | 10:19 PM
Default Re: (cb07)
The fuel pump is working thanks for the reply though, i am thinkin the distributer maybe but i dont know how to check it (if you can)
Old Jun 24, 2007 | 09:59 AM
Default Re: (Drizzle_kid)
I have been messin with the motor all day and i found no O2 senser, it has an after market greddy header (4-2-1) on it. when i start it up it idles kind of high then i give it gas and it bogs down alot, almost to stalling, and then backfires like crazy.
Old Jun 24, 2007 | 10:15 AM
rex89si's Avatar
Default Re: B16a in CRX motor is boging out PLEASE HELP!!!!!!! (Drizzle_kid)
Mine did something like this. It was a loose rotor screw.
Old Jun 24, 2007 | 02:00 PM
HondaHeddie's Avatar
Default Re: B16a in CRX motor is boging out PLEASE HELP!!!!!!! (rex89si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rex89si &raquo;</TD></TR><TR><TD CLASS="quote">Mine did something like this. It was a loose rotor screw.</TD></TR></TABLE>
X2
b4 I figured this out...
Mine would run fine for months, then it would stumble all of a sudden then die and not restart.
I would mess around under the hood and it would start again.
I found that a repair someone else did was indescribably bad. The rotor was flopping around on the shaft.
They stripped the rotor screw, I can neither tighten nor replace the rotor.
I had to put some epoxy putty in the hole to secure the rotor because I was 800miles from home in the emptyness of Indiana.
I plan on buying myself a dremmel type tool and getting the rotor swapped out.
I am not sure about the threads in the shaft, but I will x that bridge when I come to it.
crx 28
May 2, 2010 11:14 AM
C-rexproject
Apr 11, 2007 05:02 PM
umaduainttommy
Jan 25, 2006 03:32 AM
Sanj
Sep 10, 2005 07:52 PM
