Solid CEL and cant Rev Past 4k???
hey guys i dont know what the hell is going on with my car ok this is what happend i swaped out my intake manifold from a 91 civic DX to a 90 crx DX after i put the crx one on that when i got the CEL and it Wont rev past 4k today i swaped them back and it still doing the same thing any one have any ideas?? thanks any bit of help will work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX »</TD></TR><TR><TD CLASS="quote">no it throws 16 wich is injectors but it threw that before this all happend
what plugs my sparkplug wires??</TD></TR></TABLE>
I think he was refering to the plugs on the manni
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamRedline89Hatch »</TD></TR><TR><TD CLASS="quote">Why did you switch the manifolds dood?</TD></TR></TABLE>
X2
X2
cus i thought that would fix my injector code on my ecu
but i fixed that part its turns out that one of the prongs in the injector was bent so it was pretty much not fireing so i put a nother one in and that fixed my CEL and Not leting me pass 4k but i still throw code 16 and after about 5-10 of driving my CEL will turn on and stay on till i turn off the car so fixed one problem and got a nother one lol
one of your injector plugs isnt giving a signal to the injector.Which in turn is causing that cylinder to run lean. Which in turn is causing your ecu to run in a kind of limp mode.......This use to happen to me all the time..... Just make sure your injector clips are all making good connections to your injectors.Get up...and keep moving soldier.
BLacK FirE
Jul 13, 2006 01:56 PM
zeroracerh
Mar 13, 2004 04:40 PM
5thgen
12
Dec 5, 2003 06:12 PM
