No fuel...need help please
hello everyone...so i been troubleshooting my bro crx for a while now and i've found that he has spark but no fuel. i pulled off the line from the fuel resivore and cranked it and no gas shoots through it...i check the connectiion from the fuel pump and the connection is good. and we just replaced it about 2,000 miles ago....any help would be much apprciated..thanks
Fuel Relay right above the hood latch on driver side. need a 10mm wrench to slowly remove the bolt that holds the relay. Pull latch mount off..much easier to get too
sorry should have put more info...well main relay is good checked it on my boys rex and it starts right up, then oput his in my car and still no fuel..all fuses are good too...i think im going to pull out the fuel pump and check it out...any1 know how to test it????thanks 4 all your replys guys
easy fix for main relay. pop off the cover and heat up all solder points, and add some more solder. after years of having a load on the circuit, the old solder connections start to heat up and cool down. this cause a ring like break around the component.
check step 4 above
just had this happen and the connector was old loose and dirty
after you verify there is voltage for the pump there, clean and retension the connector. then plug and unplug it a few times
and your pump should start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">easy fix for main relay. pop off the cover and heat up all solder points, and add some more solder. after years of having a load on the circuit, the old solder connections start to heat up and cool down. this cause a ring like break around the component.</TD></TR></TABLE>
the fix is easy
getting the relay out to fix is a bitch
the fix is easy
ok guys latest update took out the fuel pump and aplied 12 volts and its good..so unfortunalty leaving me kind of stumpped..well the main relay is good and the fuel pump, so my car smart friend said that i either have a short some where or i have a bad ignition switch..what do you guys think...thanks for all your replys guys
From: I told you to wait in the truck in Texas, United States
Does the check engine light come on then go out when
the key is turned on?
If not,replace fuse #14 labeled alternator,solenoid
with a known good fuse..
terminaloverlowd
Jun 19, 2004 07:01 PM
