Fiberglass question inside
hey guys i have been searching for the past couple of hours through the archives and stuff and cant find anything but dead links and useless info.
so here is the situation:
i have an after market fiberglass front bumper
i have two holes about the size of my fist on my front bumper how do i close them up?
also there are a few other places that i would like to make fit better (around my headlights and fog lights)
cant find any how-tos on this subject for some reason.
if you can help me search too that would be awesome.
so anyone know how to work fiberglass or any helpful links?
TIA
TIA
I actually fixed a Backyard Special bumper that had 2 huge holes in it. I sanded the back down and layed a couple of sheets of fiberglass on the back overlaping the hole about 2-3 inches on each side. Then I came and filled the front in with some fiberstrand followed by a thin coat of filler. I really didn't use much fiberstrand since the glass layed in the hole pretty well. The guy hasent had any problems with it and its been about 2 years now. Hope this helps.
okay sounds fairly simple enough. i have never worked fiberglass before so can you explain the process to me?
how many layers of mat? cloth?
how much resin and hardener?
filler like bondo right?
as you can tell my knowledge is slim to none on this one thanks again
Modified by blk2mid2sol at 9:24 PM 6/23/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk2mid2sol »</TD></TR><TR><TD CLASS="quote">okay sounds fairly simple enough. i have never worked fiberglass before so can you explain the process to me?
Modified by blk2mid2sol at 9:24 PM 6/23/2007</TD></TR></TABLE>
I used the cloth with about 3-4 layers on the back. Overlaping as you go about 1/2 inch. The resin should use 10 drops of hardener per ounce. I wouldn't really suggest using bondo. I only use Evercoat filler products, so I couldn't tell you about Bondo. Though I have heard bad stories about it. Fiberglass is very easy to work with. I would suggest using a paintbrush to apply it to the fiberglass. Goodluck and post pics of the process. If you need anymore help let me know.
thanks! i just picked up the fiberglass products today probably will be working on it later this week. i dont have an upload cable for my camera at the moment but when i get it in ill try to post some pics.
thanks again
thanks again
phrenzy
Sep 26, 2012 06:53 PM
LoveOfMoney
Jun 16, 2005 09:09 PM
HatchBox
Jul 16, 2004 01:50 PM
hopefully it works out alright
