b18 into an EF (tranny)
Old Jun 6, 2002 | 08:14 AM
89Si's Avatar
Default b18 into an EF (tranny)
Can I use any B series tranny if I want to put a b18a or b18b? And will the 90-93 LS shift linkage fit right in? Has anyone come across any other problems or tricks that i might be able to use? thanks.
Old Jun 6, 2002 | 08:16 AM
EL Vap133's Avatar
Default Re: b18 into an EF (89Si)
As long as it's a cable tranny and it isn't Automatic, yes. I believe you still have to modify the shift linkage though.
Old Jun 6, 2002 | 08:23 AM
89Si's Avatar
So I could use a 94 ls motor and a 92 ls tranny?
Old Jun 6, 2002 | 08:33 AM
Flexmyrex's Avatar
yes you can use any b series motor w a b series tranny, as long as its cable.
Old Jun 6, 2002 | 08:39 AM
flat-blk-HB's Avatar
Default Re: b18 into an EF (flexmyREX)
a 94 LS with a 92 tranny would be alright.
Old Jun 6, 2002 | 09:14 AM
WuShu's Avatar
New User
Default Re: b18 into an EF (ED6)
all b series trannies fit all b series motors. the shift linkage will work but you will need to cut it and weld it, its too long.
Old Jun 6, 2002 | 09:19 AM
Eggman's Avatar
yeah 90-93 integra cable trannies are the ones. but the shift linkage will not work. you will need a custom linkage. usually it depends on where the motor sits and different mount kits sit the motor differently. basically buy the linkage with your mounts. hth
Old Jun 6, 2002 | 10:05 AM
Doodoo's Avatar
You just have to match the clutch disk to the tranny. 90-91 is different than 92-93.
[Modified by Doodoo, 1:05 PM 6/6/2002]
Old Jun 6, 2002 | 10:06 AM
Urban Business
Guest
Posts: n/a
Default Re: b18 into an EF (Doodoo)
you need an adjustable shift linkage, 90-93 teg axles and intermediate shafts work fine w/ everything. take out dust shields in hubs
brooklynEG
14
Feb 5, 2011 05:44 AM
ramonjones16
Aug 13, 2009 10:44 PM
gursh d
Jun 12, 2007 01:01 PM
loosestool
Sep 17, 2006 11:50 AM
fmfkid250
Apr 27, 2004 11:05 PM
