car wont start main relay doesn't click
Old Jun 23, 2007 | 04:07 PM
si90rex's Avatar
Default car wont start main relay doesn't click
the cel stays on as so as i turn the key! wont start main relay has power, but no out put to injectors or fuel pump?
thanks for any help
Old Jun 23, 2007 | 04:38 PM
yz125rider21's Avatar
had this same problem....check the fuses under dash think say acc or something 10amp fuse that cause it to do that....dont quote me on what it says but I will check in a lil bit when I start working on my car....let you know which one caused the same thing for me.
Old Jun 23, 2007 | 05:42 PM
si90rex's Avatar
Default Re: (yz125rider21)
ecu doesn't even light up.
Old Jun 23, 2007 | 08:34 PM
Crx Jimmy's Avatar
Default Re: (si90rex)
check the alt/sol fuse its in the top left of the under dash fuse box I think its a 10amp between 2 15 amp fuses. IF this goes bad the ecu doesnt get power as well as the fuel pump. It could also be your ignition switch which is fairly common as well.
Old Jun 24, 2007 | 03:49 PM
si90rex's Avatar
Default Re: (Crx Jimmy)
fuse are all fine, but i did wiggle the fuse and the car starts and runs fine now. thanks for all the help.
Old Jun 24, 2007 | 03:51 PM
altoid's Avatar
how do you know if its the ignition?
Old Jun 24, 2007 | 05:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex &raquo;</TD></TR><TR><TD CLASS="quote">fuse are all fine, but i did wiggle the fuse and the car starts and runs fine now. thanks for all the help.
</TD></TR></TABLE>ya samething with mine...probably gonna have to shim the fuse with a piece of thin metal or pull the hole fuse block out and fix it but I just shimmed mine and never had the problem again...thats how it came back to me after stolen and took me the longest time to pin point the problem but glad to see you got it going.
Old Jun 24, 2007 | 05:53 PM
si90rex's Avatar
Default Re: (altoid)
http://techauto.tripod.com/mainrelay.htm try this site
EFJohnny
May 18, 2016 08:01 AM
91b18a1ls
Nov 23, 2010 11:29 AM
EJ1_203
Sep 10, 2006 04:36 PM
93turbo16
Jun 18, 2006 12:19 PM
crazyemokid
35
Jun 8, 2006 12:08 PM
