Tacho Needle going in reverse!!!
Old Jun 23, 2007 | 03:30 PM
kmfdmww3's Avatar
Default Tacho Needle going in reverse!!!
so recently i installed a NR EL gauge cluster in my 02 accord. all the needles were working fine after installation. after a few mins of driving i noticed that my tach was a lil off and my speedo was a lil off so in the midst of adjusting the tacho needle now when i rev the engine the needle goes the wrong way. Anyone know what this problem is and how would i go about fixing it???
Old Jun 23, 2007 | 05:51 PM
AJ06's Avatar
undo whateevr u did?
Old Jun 23, 2007 | 06:56 PM
menappi's Avatar
Default Re: (AJ06)
x2. . PM me if you have questions... I might be able to help if reversing it doesn't help.
Old Jun 23, 2007 | 07:44 PM
kmfdmww3's Avatar
all i did was install the faces that go over the original factory faces.... i had to take the needles out to put the faces on then put the needle back in....no matter how many different times i take the needle out and readjust it, it stills seems to idle up but when i rev the engine it revs the opposite way.
Old Jun 23, 2007 | 07:59 PM
JDM_Acccord's Avatar
Default Re: (kmfdmww3)
isnt there a stud that prevents the needle from going below zero?.. everytime you rev does it hit that stud?
Old Jun 23, 2007 | 08:12 PM
kmfdmww3's Avatar
yes there is the stud blocking it from zero but i test it out by setting it at 1000 rpms and i have to rev it pretty high for the tach to even move and when it does move it moves in reverse.
Old Jun 23, 2007 | 09:15 PM
fastazzf22's Avatar
Sounds like you broke something ?? From my experience I have never had that problem when swapping the face plate. Good luck ..
Roanoke is my home town .. BIG OL NOKE !!
Old Jun 23, 2007 | 09:45 PM
361 accord's Avatar
Default Re: (fastazzf22)
hmm, video?
Old Jun 24, 2007 | 05:17 AM
kmfdmww3's Avatar
if i did break something where would i be able to get that fixed at? would i need a new cluster??
Old Jun 24, 2007 | 07:20 AM
fastazzf22's Avatar
yeah I would just buy a new cluster . should get them for 50 bux in roanoke . If you cant get them any cheaper give me a holla.. My step dad is a big parts director up there. I get **** at cost all the time. Only factory parts.
Old Jun 24, 2007 | 11:30 AM
5spdcoupe's Avatar
maybe the needle is loose now? I dont see why it would go backwards.. weird
Old Jun 24, 2007 | 03:35 PM
kmfdmww3's Avatar
so if i buy a new cluster how will the work with the current mileage i have on my car?? couldnt i just change the tacho instead of the whole cluster. if thats possible or not. fastazzf22 hit me up on aim if you dont mind AIM:kmfdmww3
thanks everyone for trying to help been reading a lot on the boards but never posted anything.
Old Jun 25, 2007 | 06:43 AM
kmfdmww3's Avatar
Default Re: Tacho Needle going in reverse!!! (kmfdmww3)
bump
Old Jun 25, 2007 | 09:39 AM
TheMuffinMan's Avatar
He knows where you live!
new cluster + take it apart and replace the tach
most likely you messed up the tach itself.
Old Jun 25, 2007 | 11:09 AM
kmfdmww3's Avatar
Default Re: (TheMuffinMan)
ya thats what i'm going to do. thanks everyone i will post results in a few days with pics
frankhky
Oct 24, 2006 02:30 AM
J1A1H
19
Oct 3, 2006 07:17 AM
ShagPower
Jun 14, 2006 01:28 PM
Chuji
Mar 3, 2005 01:22 PM
AllmotorJunkie
Aug 20, 2003 05:14 PM
