Just finished wet sanding some spots, and i think i f*ed up, please help
Old Jun 23, 2007 | 03:10 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Just finished wet sanding some spots, and i think i f*ed up, please help
Just finished wet sanding a couple spots.... Used 1000 grit... After wet sanding could see some swirl marks, which I assume is normal, and I tried using some polishing compound then wax... This did NOTHING! There are still swirl marks you can see that are very visible...
Is the wax im using not good enough? Its meguires, but it seems very thin and liquidy, not thick at all. Please help, it looks like total crap and I dont wana drive it to work Mon if it still looks like this.. I really need help guys, the paint job looked great except the spots I tried to wet sand out, and now it looks even worse with what seems to look like the cear coat is completely gone...
I also tried Meguires scratch X wich seemed to help but only a VERY little... Still looks like total CRAP. Any help, MUCH appreciated!!
Modified by EJ8VTEC at 7:47 PM 6/23/2007
Old Jun 23, 2007 | 03:13 PM
shad0wslay3r's Avatar
pictures..?
Old Jun 23, 2007 | 03:14 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (shad0wslay3r)
cant find my usb hook up right now....
Old Jun 23, 2007 | 04:01 PM
EJ8tunerman's Avatar
Default Re: (EJ8VTEC)
heres the problem...you used too rough of grit to wetsand and on top of that your trying to hand rub 1000 grit sanding marks by hand which could barely be removed with a rotary and wool pad....most of your problem is that you just didnt FINISH with a finer grit.. Go either get some 3m wet or dry or the preferred meguiars unigrit paper. Now that youve sanded with 1000 grit, hit every spot lightly with 2000 followed by 3000. After that either get a Porter cable or a Rotary with a foam cutting pad and an aggressive polish, followed by a polishing pad and a finer or finishing polish. As long as you didnt go through the clear when you were wetsanding, this should turn out perfect.
Old Jun 23, 2007 | 04:11 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (EJ8tunerman)
ok, thanks alot bro... hopefully i can find that higher grit paper... the highest i found at home depot was 1000... ill try auto zone or something like that.
Old Jun 23, 2007 | 04:20 PM
EJ8VTEC's Avatar
Mr. Indecisive
can anyone give me an example of a more agressive polish
Old Jun 23, 2007 | 04:38 PM
Meguiars #85, 84, 83, Optimum Hyper compound, optimum compound, Hi-temp extreme cut, Poorboys world SSR3 or 2.5, and many more. Because that fact that you chose to wetsand your car with what I believe is wood sandpaper from home depot, I dunno if youll be able to correct it or not.
Old Jun 23, 2007 | 04:41 PM
why did you wetsand those places anyway?
Old Jun 26, 2007 | 09:16 AM
GarageAlchemist
Guest
Posts: n/a
you don't want to use sandpaper from home depot, use some thats made for wet sanding, ug i forget the brand but its at napa/advanced auto, etc...
Old Jun 26, 2007 | 06:27 PM
http://cgi.ebay.com/ebaymotors...d=1,1
there's some 2000 grit, I buy most of my supplies from him, lots of nice 3M stuff.
Old Jun 27, 2007 | 10:59 PM
johnxboi's Avatar
the best stuff out there today is the 3m rubbing compound. used in most body shops.
Old Jun 28, 2007 | 02:46 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (GarageAlchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">you don't want to use sandpaper from home depot, use some thats made for wet sanding, ug i forget the brand but its at napa/advanced auto, etc...
it was wet sand paper, same as sold at the autozone by me....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shad0wslay3r &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...d=1,1
there's some 2000 grit, I buy most of my supplies from him, lots of nice 3M stuff.</TD></TR></TABLE>
thanks
DTejeda93
Paint and Body
May 29, 2018 11:17 PM
tyronne1126
Paint and Body
Jun 26, 2009 05:00 PM
ek4shizzle
Paint and Body
Jul 28, 2007 11:19 AM
IamPhil
Paint and Body
38
Jul 10, 2007 11:24 AM
towelie
Honda Fit
Jan 25, 2007 10:28 PM
