fix sunroof... but i think i messed up the relay:S need help
I took apart the sunroof switch, cleaned it up and it was workin perfect. then on the same day the sunroof stopped workin properly. It will raise up but wont retracted back. the switch is workin perfectly it just wont retract back the relay clicks after it raises. my question is, is the relay for the sunroof in the fuse box or where? thanks for any help
the sunroof relay plugs into the back side (at bottom) of the under dash fuse box, right next to the Integrated Control Unit
