really need help finding...
Old Jan 21, 2003 | 02:54 PM
13_sec_'89PreludeSi's Avatar
Default really need help finding...
First of all my problem is that sometimes when its hot my car doesnt start. When i turn my key on the engine light wont go off and my car just wont start. It cranks and cranks but wont start.
I found out that its the main relay fuse somewhere under the dash. I just need to replace it because its old and not working right.
If anyone knows what im talking about please tell me where to find it. Any help will be greatly appreciated.
thanks
Old Jan 21, 2003 | 03:07 PM
3gdude's Avatar
Default Re: really need help finding... (13_sec_'89PreludeSi)
Yeah your main relay went bad. Its under the dash on the driver side, left of the steering column. Look for a gray colored relay mounted on a bracket. It has the words Main Relay written on it. If you replace it your problem will most likely be fixed. Most all of these can be repaired by resoldering the bad solder joints. If you look at it with a magnifying glass you will see what looks like a crater right in the middle of the solder. I fix them all the time, you just have to be able to solder real good......3gdude
Old Jan 21, 2003 | 03:28 PM
Default Re: really need help finding... (3gdude)
i still cant find it. Do i have to take apart the dash or can i just find it if i look from the bottom.
SunnyJDM
10
Aug 19, 2008 10:08 PM
89txrex
Sep 2, 2005 01:44 PM
DirtyBirdJR
Aug 29, 2005 02:59 PM
RLOWE
Aug 1, 2004 10:30 AM
gaber
Jul 22, 2004 12:20 PM
