Pleas help, ob0-obd1 gsr problems! Searched, called, read, re-checked!
Old Jun 23, 2007 | 12:33 PM
white90rexsi's Avatar
Default Pleas help, ob0-obd1 gsr problems! Searched, called, read, re-checked!
Hey everyone. To start off here is my setup. 1990 crx si. Fresh b18c1 gsr swap. Locash racing obd0-obd1 ecu adapter+v-tec harness+dizzy harness( bought 2-years ago before rywire was around), rywire modified si harness (obd1 injector plugs, resistor pack eliminated, fan switch relocated) brand new obd1 dizzy from rywire, chiped p06 from rywire (said its the same is a p28) Here is the deal.
I finish the swap last week and it wont start. I have no spark. I check some diagrams on honda-tech and it turns out locash racing wired the dizzy adapter harness wrong. I re pined it according to a diagram posted by honda parts hero and I have spark!
The car still wont start. So I pull my plugs and I am not getting fuel. My fuel pump IS coming on and I AM getting fuel at the rail but my injectors will not spary. I am getting a +12.6 volt to each injector but they will not spray. I ohm them and even tried another injector, it is not the injectors, they are not getting a signal. Now I checked the pins at the obd0 side (stock harness) down by the ecu and I am getting continuity from the ecu pin to the injector pin. The only things I see left that could be to blame are a miswired ecu jumper( they misswired the dizzy adapter maybe they did this to) or a bad ecu (which I dont think is the case because this one comes on and is read, and I am getting spark). The only code I am getting is 22 for v-tec pressure switch because I do not have one instaled in my v-tec solonoid ( I still need to drill and tap this one).
Any ideas?
-Chris
Modified by white90rexsi at 2:21 PM 6/23/2007
Old Jun 23, 2007 | 12:36 PM
jlicrx's Avatar
Default Re: Pleas help, ob0-obd1 gsr problems! Searched, called, read, re-checked! (white90rexsi)
is the ground wire at the thermostat housing connected?
Old Jun 23, 2007 | 01:13 PM
Default Re: Pleas help, ob0-obd1 gsr problems! Searched, called, read, re-checked! (jlicrx)
Yes, all grounds are connected, thermo. housing, valve cover, and trans.
-Chris
Old Jun 23, 2007 | 09:39 PM
Bump, Any ideas?
Old Jun 24, 2007 | 11:52 AM
N_A_is_best's Avatar
your problem is that rywire wires the distributor differently than locash does... the jumper itself is different if you have a locash jumper you would need to wire the distributor accordingly to how locash says .... i made this same mistake and my injectors didnt fire
Old Jun 24, 2007 | 12:30 PM
Default Re: Pleas help, ob0-obd1 gsr problems! Searched, called, read, re-checked! (N_A_is_best)
Do you have intructions on how you wired it? I wired it acording to a post made by honda parts hero, a member on this board. Did your swap still spark when you injectors did not?
Old Jun 24, 2007 | 12:49 PM
yes my car still spark the injector just didnt pulse : i hope this helps you out this is off the locashracing.com site
OBD0 (Harness Side) OBD1 OEM Dist.(Distributor Side)
Blue w/Green Stripe Orange*
Blue w/Yellow Stripe White*
Orange w/Blue Stripe Orange w/Blue Stripe
White w/Blue Stripe White w/Blue Stripe
Orange Blue w/Green Stripe
Thin White Blue w/Yellow Stripe
Thick White** Yellow w/Green Stripe
*Note 1: On some aftermarket OBD1 distributors, the Orange and the White wire are swapped.
**Note 2: If you confuse the two OBD0 white wires, the car will not start and could cause ignitor failure!
Old Jun 24, 2007 | 03:14 PM
I have an aftermarket distributor. I have been told that the wires do not match up. What should I do?
Thank you for all your help! I have been getting so mad that I couldent figure it out all weekend.
-Chris
Modified by white90rexsi at 4:44 PM 6/24/2007
Old Jun 25, 2007 | 05:20 PM
Ok, I tried wireing it color to color, and swaping thw 2 wires and I have no spark and no fuel now . Tomorrow after work im going to try and go over everything again. Im running out of ideas here.
-Chris
Old Jun 26, 2007 | 10:49 AM
you have the locash jumper just go off of thier website.. only real help i can give
Old Jun 27, 2007 | 03:49 AM
I repined the dizzy harness and now when i turn my key "on" the main relay clicks on and off rapidley. I put the wireing back to how it was and the relay is still clicking on and off fast.
jorge c.
Jul 12, 2012 06:08 PM
crazydude107
Aug 24, 2008 02:43 AM
white90rexsi
Jun 22, 2007 06:21 PM
boost_guy
Jun 4, 2006 01:50 PM
Kusai.Nihonjin.Desu
21
Apr 16, 2005 08:08 PM
