LS Vtec Turbo??
Old Jun 23, 2007 | 12:24 PM
J_M_B's Avatar
Default LS Vtec Turbo??
i have a b18b and i wanted to put a b16 head on it and hook my turbo kit up to that so it will be lsvtec turbo but one of my friends says it will blow up if i do that and says you cant make a lsvtec turbo cause it makes it a high compression motor is he right and is this a waste of time??
Old Jun 23, 2007 | 12:37 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: LS Vtec Turbo?? (J_M_B)
Ugh, where to start.
It's not as simple as you're making it sound. Do some research and get back to us.
Old Jun 23, 2007 | 12:38 PM
94c1v1cex's Avatar
ya man just "hook" that turbo kit up
edit: guess i should put somethin helpful in here: go research man it helps alot spend some time in forced induction section
Old Jun 23, 2007 | 12:55 PM
doood's Avatar
been there done that
Default Re: LS Vtec Turbo?? (94c1v1cex)
you need new friends. preferably people that know how an engine works.
you also need lots of research.
Old Jun 23, 2007 | 01:15 PM
J_M_B's Avatar
Well i am getting weisco pistons with eagle rods, i am having the motor sleeved and bored i was just wondering if i should leave the stock head on the b18b or replace it with the b16??
Old Jun 23, 2007 | 01:19 PM
DaveF's Avatar
put the b16 head on, your friends are slow.
Old Jun 23, 2007 | 01:23 PM
ifIexplode's Avatar
boosted LSV is a touchy subject, I think.
a friend has that setup in his hatch.
tune tune tune
even with that, hes got the motor ripped down every six months.
Old Jun 23, 2007 | 01:25 PM
doood's Avatar
Default Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">boosted LSV is a touchy subject, I think.
tune tune tune
even with that, hes got the motor ripped down every six months. </TD></TR></TABLE>
must be a crappy build/tune
Old Jun 23, 2007 | 01:26 PM
J_M_B's Avatar
well i only plan to run about 15 pounds and i dont plan on going cheap on the tune job. Plus i plan to put new cams and gears with valves in the head
Old Jun 23, 2007 | 01:40 PM
Ek Forever y0!
Default Re: (J_M_B)
15 lbs on a t3/t04 is WAY different than 15 lbs on a t4 garret.
Do a little more research so you make sure you get what will make you happiest.
JDM_NANO
Oct 2, 2011 06:24 AM
hatchvtec
13
Oct 17, 2005 08:34 AM
SnkyPY
Jul 15, 2004 02:29 PM
mz3bo
42
Feb 1, 2003 08:26 AM
